Built In Speakers Not Working Properly After Testing HDMI
I have had Garuda Installed for a little while now, and everything was working fine. I went to test the HDMI port yesterday, and changed my audio settings to play through the TV speakers. Ever since, my laptop speakers don’t want to play anything. If i use the Garuda Live Disc, the audio there works fine, and if I hit restart from there and boot into the actual install the audio will continue to work, but if I shut down instead of restart, the audio will once again not work once I boot up again. I’ve tried just about any audio setting I can think of. Any help would be greatly appreciated. Thanks
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=653346b0-e41e-4682-af8a-c8daab7c68bd rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-E43C1C25D4880AD6
Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1
serial: <superuser required> UEFI: Apple v: 486.0.0.0.0 date: 08/03/2023
ID-1: BAT0 charge: 61.5 Wh (100.0%) condition: 61.5/74.8 Wh (82.3%)
volts: 12.9 min: 11.4 model: SMP bq20z451 type: Li-ion serial: N/A
status: full cycles: 336
Info: model: Intel Core i5-5287U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2902 high: 2904 min/max: 500/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2904 2: 2902 3: 2900
4: 2903 bogomips: 23199
Device-1: Intel Iris Graphics 6100 vendor: Apple driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:162b
Monitor-1: eDP-1 res: 2133x1333 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Graphics 6100 (BDW
GT3) device-ID: 8086:162b memory: 15.16 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 7 device: 0 type: integrated-gpu name: Intel
Iris Graphics 6100 (BDW GT3) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:162b surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-1: Apple Bluetooth Host Controller driver: btusb,hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
chip-ID: 05ac:8290 class-ID: fe01
Local Storage: total: 233.76 GiB used: 67.82 GiB (29.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3A0Q scheme: GPT
ID-1: / raw-size: 233.46 GiB size: 233.46 GiB (100.00%)
used: 67.82 GiB (29.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 233.46 GiB size: 233.46 GiB (100.00%)
ID-4: /var/log raw-size: 233.46 GiB size: 233.46 GiB (100.00%)
ID-5: /var/tmp raw-size: 233.46 GiB size: 233.46 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 89.0 C pch: 76.5 C mobo: N/A
Processes: 214 Uptime: 9m wakeups: 0 Memory: total: 16 GiB
available: 15.52 GiB used: 3.03 GiB (19.5%) Init: systemd v: 254
pm: pacman pkgs: 1407 libs: 406 tools: octopi,pamac,paru,trizen,yay
Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-12
Last full system update: 2023-12-03 ↻
Try changing the sound card in alsamixer.
alsamixer
Press F6 to switch the sound card to whatever you laptop speakers are, then make sure it is unmuted.
Thank you for the reply, however that doesn’t seem to help either.
Let’s try this:
systemctl --user restart wireplumber pipewire pipewire-pulse
The ‘swish’ says you need to reboot since your last update. Nothing’s guaranteed to work right if you don’t reboot when needed. :smiley:
Thanks for the replies. I previously had rebooted as part of my attempts, then searched for updates once again hoping that would help. Just to rule that out i did once again try rebooting. I also tried
to no avail.
ID-1: BAT0 charge: 54.2 Wh (88.3%) condition: 61.4/74.8 Wh (82.1%)
volts: 11.8 min: 11.4 model: SMP bq20z451 type: Li-ion serial: N/A
status: discharging cycles: 336
Speed (MHz): avg: 1839 high: 2901 min/max: 500/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 500 2: 2901 3: 1471
4: 2487 bogomips: 23200
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api with: aoss
Local Storage: total: 233.76 GiB used: 59.94 GiB (25.6%)
used: 59.94 GiB (25.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 89.0 C pch: 82.5 C mobo: N/A
Processes: 212 Uptime: 3m wakeups: 0 Memory: total: 16 GiB
available: 15.52 GiB used: 2.76 GiB (17.8%) Init: systemd v: 254
pm: pacman pkgs: 1410 libs: 406 tools: octopi,pamac,paru,trizen,yay
Garuda (2.6.19-2):
It sounds like a bit of kernel nonsense. You haven’t mentioned trying other kernels. Have you?
I hadn’t prior to your response, but I tried the LTS Kernel after, and still nothing. I did discover that even if I select the main drive instead of the Live USB the speakers seem to work after booting.
  1. If you revert that, what happens?
  2. How are your HDMI cables/connections. Quality matters.
Slightly off topic, but what should we have installed as a good “default” for Audio? I have PIpeWire support only, no ALSA. Reading the descriptions, it seems like it should be on or the other but I may be missing something.
Everybody needs ALSA, and either Pulseaudio (old), Pipewire (new), or JACK (for audiophiles).
Typically/normally, ALSA + Pipewire w/wireplumber as session manager would be what you’d want.
So I ended up backing up and reinstalling, and everything works fine now. I’m not entirely sure what the issue was, but thanks for the tips.
