Hello, I'm having some problem restoring from a BTRFS snapshot using the GRUB menu.
The pop-up asking me if I wanted to restore the system to that snapshot no longer appear making the grub menu useless.
Kernel: 5.16.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=995b984e-0171-4ed2-adff-0bc76cdf57e5 rw rootflags=subvol=@
vt.global_cursor_default=0
resume=UUID=3aa21218-c4c0-4f6c-b01d-a03bd160addb
systemd.unified_cgroup_hierarchy=1 mitigations=off intel_iommu=on
iommu=pt acpi_enforce_resources=lax snd_hda_intel.dmic_detect=0
snd-intel-dspcfg.dsp_driver=1 ignore_loglevel
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Mobo: ASUSTeK model: ROG MAXIMUS XII FORMULA v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 2301 date: 07/13/2021
ID-1: hidpp_battery_0 charge: 65% condition: N/A volts: 3.9 min: N/A
serial: <filter> status: Charging
Info: model: Intel Core i9-10900K socket: LGA1200 bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xEE
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 5001 high: 5303 min/max: 800/5300 base/boost: 3663/8300
scaling: driver: intel_pstate governor: performance volts: 0.9 V
ext-clock: 100 MHz cores: 1: 4900 2: 4902 3: 4901 4: 5059 5: 5303 6: 5296
7: 5279 8: 5065 9: 5224 10: 5083 11: 4900 12: 4901 13: 4900 14: 4901
15: 4901 16: 4912 17: 4902 18: 4900 19: 4902 20: 4901 bogomips: 147994
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b81
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2.2:10 chip-ID: 046d:082d
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 7280x1440 s-dpi: 109 s-size: 1696x333mm (66.8x13.1")
s-diag: 1728mm (68")
Monitor-1: DP-0 res: 1920x1080 dpi: 92 size: 531x298mm (20.9x11.7")
diag: 609mm (24")
Monitor-2: DP-2 res: 1920x1080 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
Monitor-3: DP-4 res: 3440x1440 dpi: 109 size: 800x330mm (31.5x13.0")
diag: 865mm (34.1")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
Device-3: Logitech HD Pro Webcam C920 type: USB
Device-4: RODE Microphones RODE NT-USB type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 19f7:0003
Sound Server-1: ALSA v: k5.16.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-2: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel port: N/A bus-ID: 04:00.0
chip-ID: 1d6a:07b1 class-ID: 0200
Device-3: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3 class-ID: 0200
bus-ID: 1-14:12 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Comet Lake PCH-H RAID driver: ahci v: 3.0 port: 4020
bus-ID: 00:17.0 chip-ID: 8086:06d6 rev: class-ID: 0104
Local Storage: total: 1.61 TiB used: 46.34 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT343.4
temp: 28.9 C scheme: GPT
SMART: yes health: PASSED on: 80 hrs cycles: 47
read-units: 403,121 [206 GB] written-units: 551,785 [282 GB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
family: based SSDs size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 2B6Q temp: 26 C
SMART: yes state: enabled health: PASSED on: 1y 282d 18h cycles: 2792
written: 32.81 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
SMART: yes state: enabled health: PASSED on: 1y 330d 4h cycles: 3067
written: 40.9 TiB
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
rev: 1B6Q temp: 26 C
SMART: yes state: enabled health: PASSED on: 3y 119d 11h cycles: 2656
written: 40.93 TiB
ID-1: / raw-size: 919.29 GiB size: 919.29 GiB (100.00%)
used: 46.34 GiB (5.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 919.29 GiB size: 919.29 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 919.29 GiB size: 919.29 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 919.29 GiB size: 919.29 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: partition size: 34.28 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 32.5 C mobo: 34.0 C gpu: nvidia temp: 37 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1555 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 901 fan-7: 0 gpu: nvidia fan: 0%
Processes: 491 Uptime: 1m wakeups: 4 Memory: 31.16 GiB
used: 4.03 GiB (12.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: note: see --pkg pacman: 1732 lib: 477
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
Garuda (2.5.5-1):
System install date: 2022-02-13
Last full system update: 2022-02-21
Failed units: systemd-guest-user.service
