BT headset connect but disconect when i play any sound
I recently update my laptop and after the update before the reboot my headset disconect. I didnt think a lot of it. But after reboot imposible to play any sound on it. Every time i trie it get disconected. I read arch wiki and tried some things. I copy the config that was at /share/usr/pipwire cause the folder at etc/pipewire was empty but it still doesnt work i tried other things and can put min finger on it.
wpctl status give me this
PipeWire 'pipewire-0' [0.3.72, serial@serial-cremwxx9, cookie:1665772584]
└─ Clients:
32. xdg-desktop-portal                  [0.3.72, serial@serial-cremwxx9, pid:2070]
33. WirePlumber                         [0.3.72, serial@serial-cremwxx9, pid:2307]
34. WirePlumber [export]                [0.3.72, serial@serial-cremwxx9, pid:2307]
60. pipewire                            [0.3.72, serial@serial-cremwxx9, pid:2760]
61. telegram-desktop                    [0.3.72, serial@serial-cremwxx9, pid:2488]
62. Plasma PA                           [0.3.72, serial@serial-cremwxx9, pid:2198]
63. Chromium input                      [0.3.72, serial@serial-cremwxx9, pid:3150]
67. plasmashell                         [0.3.72, serial@serial-cremwxx9, pid:2198]
70. kwin_wayland                        [0.3.72, serial@serial-cremwxx9, pid:2061]
74. FireDragon                          [0.3.72, serial@serial-cremwxx9, pid:4298]
78. wpctl                               [0.3.72, serial@serial-cremwxx9, pid:6435]
Audio
├─ Devices:
│      43. Renoir Radeon High Definition Audio Controller [alsa]
│      44. Family 17h/19h HD Audio Controller  [alsa]
│      68. WH-1000XM3                          [bluez5]
├─ Sinks:
│      49. Family 17h/19h HD Audio Controller Speaker + Headphones [vol: 0.10]
│  *   76. WH-1000XM3                          [vol: 0.31]
├─ Sink endpoints:
├─ Sources:
│      50. Family 17h/19h HD Audio Controller Headphones Stereo Microphone [vol: 1.00]
│  *   51. Family 17h/19h HD Audio Controller Digital Microphone [vol: 1.00 MUTED]
├─ Source endpoints:
└─ Streams:
Video
├─ Devices:
│      40. HD Camera                           [v4l2]
│      41. HD Camera                           [v4l2]
│      42. HD Camera: HD Camera                [libcamera]
├─ Sinks:
├─ Sink endpoints:
├─ Sources:
│  *   45. HD Camera (V4L2)
│      47. Built-in Front Camera
└─ Streams:
71. kwin_wayland
73. output_1        > plasmashell:input_1  [init]
72. plasmashell
69. input_1         < kwin_wayland:output_1        [init]
Settings
└─ Default Configured Node Names:
0. Audio/Sink    bluez_output.CC_98_8B_21_38_79.1
1. Audio/Source  alsa_input.pci-0000_03_00.6.3.HiFi__hw_Generic_1__source
Kernel: 6.4.0-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=8a5c4a7e-513b-4735-85fb-56edd6a6758d rw rootflags=subvol=@
loglevel=3 splash mitigations=off ibt=off
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Laptop System: HUAWEI product: CREM-WXX9 v: M1010
Mobo: HUAWEI model: CREM-WXX9-PCB-B1 v: M1010 serial: <superuser required>
UEFI: HUAWEI v: 2.26 date: 05/13/2022
ID-1: BATT charge: 53.3 Wh (70.0%) condition: 76.1/83.1 Wh (91.5%)
volts: 12.1 min: 11.5 model: DYNAPACK HB9790T7ECW-32T0 type: Li-ion
serial: <filter> status: not charging cycles: 131
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2776 high: 4079 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2449 2: 3465
3: 4079 4: 3374 5: 3553 6: 1200 7: 1459 8: 3553 9: 3553 10: 1200 11: 3552
12: 1200 13: 1200 14: 3553 15: 3841 16: 3200 bogomips: 102241
vendor: Wingtech driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 46.0 C
Device-2: ShineTech HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 3277:0003
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
Monitor-1: eDP-1 res: 1626x1084 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.0-AMD-znver3) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Wingtech
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Wingtech
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Wingtech
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.4.0-AMD-znver3 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
vendor: & Tele RSH driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
Device-1: Realtek 802.11ac WLAN Adapter driver: btusb v: 0.8 type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 1358:c123
Local Storage: total: 476.94 GiB used: 424.05 GiB (88.9%)
model: PC SN730 SDBPNTY-512G size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11120000 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
used: 424.05 GiB (92.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-4: /var/log raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.48 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 14.99 GiB used: 11 MiB (0.1%) priority: 100
System Temperatures: cpu: 55.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
Processes: 411 Uptime: 4m wakeups: 15817 Memory: available: 14.99 GiB
used: 6.17 GiB (41.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1760 libs: 528 tools: octopi,paru Shell: fish v: 3.6.1 default: Zsh
v: 5.9 running-in: yakuake inxi: 3.3.27
System install date:     2023-03-05
Last full system update: 2023-06-30
Relevant software:       snapper tlp NetworkManager mkinitcpio
Please post always your terminal in- and output as text like
Kernel: 5.18.15-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters:
looks like
    parameters:
in forum.
I have edited your post.
Having the similiar if not same issue as well. Just updated, running gnome. In bluetooth settings, when connected it will connect and disconnect immediately, but still show connected. My speakers indicate when connected and disconnected.
[ 2814.602846] bluetoothd[48742]: segfault at 20 ip 0000562472a9ffa5 sp 00007fff9bf1e8c0 error 4 in bluetoothd[562472a84000+d4000] likely on CPU 5 (core 6, socket 0)
[ 2814.602862] Code: 08 00 0f 1f 00 f3 0f 1e fa 41 55 41 54 55 53 48 83 ec 18 48 8b 2a 4c 8b 62 08 64 48 8b 04 25 28 00 00 00 48 89 44 24 08 31 c0 <48> 8b 45 20 48 8b 00 41 c7 44 24 08 00 00 00 00 85 f6 74 27 48 89
[ 2818.393946] input: VIZIO V21 (AVRCP) as /devices/virtual/input/input27
seems I'm using a different kernel
  Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
Thanks
Solution:
The first thing to do whenever you start experiencing issues with BT is to test alternate kernels such as the mainline or LTS kernels.
will do next time. I tried with the install kernel and i didnt have mainline or lts at this time, since i reinstall the os cause iit was also time for summer cleaning
