I've been using bspwm for 4 years. Decided to try Garuda version since it supports HiDPI. On my other computers running Arch and BSPWM, I have no problems with sound. Garuda has no sound. The volume control will not let me change anything. Sure would appreciate some help on how to fix.
thanks
Found that if I use Garuda Welcome and select Settings the volume control was on mute. Very bizarre way of configuring.
thanks
