having an issue with connecting to network. both my wired and wireless connections are up and running but the browsers (Chromium, Firefox, Opera) won't connect. tried disabling firewalls, played with network and device settings. still having issues
╭─[email protected] in ~ as 🧙 took 2s
[🔴] × garuda-inxi
Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=bb27ee55-86c8-4c74-93f1-06004daa8c34 rw [email protected]
splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.27.0 tk: Qt v: 5.15.8 info: latte-dock
Mobo: ASUSTeK model: PRIME Z590-A v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 0402 date: 01/08/2021
Device-1: hid-04:4b:ed:eb:cc:93-battery model: Claudia's Trackpad
serial: N/A charge: N/A status: discharging
Device-2: hid-F0T001701PPJ1XLAX-battery model: Apple Inc. Magic Keyboard
Info: model: 11th Gen Intel Core i9-11900K bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x57
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3114 high: 3500 min/max: 800/5100:5300 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 3500 3: 800
4: 3500 5: 3500 6: 3500 7: 3500 8: 2729 9: 3500 10: 3500 11: 3500 12: 3500
13: 3500 14: 3500 15: 3500 16: 3500 bogomips: 112128
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 ports: active: DP-2,HDMI-A-1
empty: DP-1,DP-3,DVI-D-1 bus-ID: 0000:01:00.0 chip-ID: 1002:67df
Device-2: Realtek NexiGo N660P FHD Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-13:9 chip-ID: 0bda:0567
Device-3: Logitech BRIO Ultra HD Webcam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-7:2
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: right model: Samsung C27F390
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: Acer EB321HQ A serial: <filter> built: 2021 res: 1920x1080 hz: 60
dpi: 70 gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon RX 580 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.12-zen1-1-zen) direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 1-13:9 alternate: snd_sof_pci_intel_tgl chip-ID: 0bda:0567
class-ID: 0102 bus-ID: 0000:00:1f.3 serial: <filter> chip-ID: 8086:43c8
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Realtek NexiGo N660P FHD Webcam type: USB
Device-4: Blue Microphones Yeti Stereo Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-7:7 chip-ID: b58e:9e84
Device-5: Logitech BRIO Ultra HD Webcam type: USB
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 0000:03:00.0 chip-ID: 8086:15f3 class-ID: 0200
Device-2: Broadcom BCM4352 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: wl v: kernel modules: bcma bus-ID: 0000:05:00.0
chip-ID: 14e4:43b1 class-ID: 0280
Device-1: Dynex Bluetooth 4.0 Adapter [Broadcom 1.12 BCM20702A0] type: USB
driver: btusb v: 0.8 bus-ID: 1-11:8 chip-ID: 19ff:0239 class-ID: fe01
Hardware-1: Intel Device driver: intel_nvme_remap v: N/A port: 4020
bus-ID: 0000:00:17.0 chip-ID: 8086:43d6 rev: N/A class-ID: 0104
Local Storage: total: 2.73 TiB used: 438.85 GiB (15.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 3B2QGXA7 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 320.67 GiB (17.2%)
used: 628 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 320.67 GiB (17.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.2 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 679
Processes: 383 Uptime: 19m wakeups: 3 Memory: 31.2 GiB
used: 4.89 GiB (15.7%) Init: systemd v: 253 default: graphical
pkgs: 1818 libs: 513 tools: octopi,pamac,paru Shell: fish v: 3.6.0
running-in: konsole inxi: 3.3.25
Garuda (2.6.14-1):
System install date: 2022-08-02
Last full system update: 2023-02-17
Is partially upgraded: Yes
Failed units: snapper-boot.service
