Browsers forgetting login data (cookies and login info). Another couple of issues too
Rewriting this because it seems i deleted the paragraphs describing the actual problem. Sorry.
Hello, for now this issue has made me left Garuda as a i need my browsers to work for my job and I’ve been dealing with the problem for some time without being able to solve it.
I’m sad because Garuda is my favorite Linux distribution by faaaar. But it’s rough on the edges in some parts.
while this is the issue that made me left for now, I will comment a couple of other things at the end, just as side comments.
This is also not the first time I encounter this error.
Recently I reinstalled Garuda and i encountered this same problem at some point too. I was updating by installing individual applications from the software center which I thought could have corrupted something due to another issue: Garuda update always encountered it couldn’t download some stuff and then it ended up not updating anything.
The problem I refer to is my browsers (Firedragon, Opera, Vivaldi, and i think Brave too) begin at some point giving this error:
Free up space to continue
Some features on [website name] might not work until you clear data that other sites have stored on your device.
(there’s no need to free up space of course there’s plenty of free space and the disk seems to work alright, no other errors or problems. (has been formatted before reinstalling too))
They also become slow, and “forget” cookies and log in data. So i have to log in everyday to the sites I use. And trying to save new log in data doesn’t work.
Then eventually I get weird things happening with other apps i use, like telegram doesn’t open, and it crashes often. It’s weird because it takes a few days for all to happen. First The free up space error appears, then days later the cookies and the login db, they don’t work, then a few days later telegram crashes. It happened the same way the first time.
I first tried checking the permissions of the browsers folders as I read on some google chrome thread but they seemed to be fine. (they were owned by my user and could be read written to etc.)
After searching here I found a couple of threads of a person with a similar problem. One user replied with something about deactivating pdb. This did work to a degree and since then telegram doesn’t crash and two of my browsers do remember log in data and cookies. (firedragon and opera. Vivaldi still is the same i think)
I used this command:
╰─λ systemctl --user disable psd
While this kinda worked, I’m not sure if it’s a real solution. Isn’t pdb needed for other stuff? Then as I said, Vivaldi is still the same it seems. And there are other errors. Some browser extensions I also need don’t work anymore. They just stopped working.
So I’m going to try some other distro just for a while. I really want to go back to Garuda as soon as I can, as really i really prefer it to other distros.
The other issues I mention are also prevalent problems in Garuda, which I will point out now, just as a side note. I have mentioned them before here.
  1. When I try to update after the first update, I get the error that some things can’t be downloaded and no update is made. Well, I refresh keyrings and mirrorlist, adding also a few other mirrors apart from those of my country (Mexico), if I just leave those, the error appears again.
But then after the update is done, in the next update, the same problem appears again. (!) And I have to update mirrors and keyrings again
This isn’t really a problem, but I wonder if it means something else that needs to be corrected. Also, it can be a big thing for someone who doesn’t know a lot about linux. (Like me, lol.)
  1. After installation there seems to be no way of avoiding configuring kde wallet. Also it seems you have to choose blowfish when creating the wallet because PGP doesn’t work. Again something that I have encountered in my last two Garuda installs.
It’s not a big problem, but aagain, for someone who doesn’t know anything about kdewallet, encription, etc, this is very frustrating, specially as the wallet requirement appears out of nowhere after installation.
I also wonder if this has to do with the other problems with the browsers, extensions etc.
Here is my Garuda inxi:
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=d03e3c1f-9c2e-43fb-899e-c40e1d82d931 rw rootflags=subvol=@
quiet resume=UUID=35b64325-de8c-4dd7-9b79-d10d16d3a8ac loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
wm: kwin_wayland tools: avail: lxlock vt: 1 dm: SDDM Distro: Garuda
Type: Server System: BESSTAR TECH product: X500 v: N/A
Mobo: BESSTAR TECH model: ATB15 serial: <superuser required> part-nu: 0001
uuid: <superuser required> UEFI: American Megatrends v: ATB15016
date: 09/23/2021
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3086 high: 3793 min/max: 400/4673 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2551 2: 3793 3: 400
4: 3169 5: 2808 6: 3793 7: 3791 8: 2526 9: 3514 10: 3793 11: 2518 12: 3519
13: 3379 14: 3792 15: 2528 16: 3507 bogomips: 121370
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: DP-1,HDMI-A-1 empty: DP-2 bus-ID: 05:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 39.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3200x2104
display-ID: 0
Monitor-1: DP-1 pos: bottom-l res: 1280x1024 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.4-arch1.2
renoir LLVM 17.0.6 DRM 3.57 6.8.2-zen2-1-zen) device-ID: 1002:1638
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.4-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.4-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Conexant Systems
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0e8d:0608
Local Storage: total: 1.83 TiB used: 287.63 GiB (15.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-A01
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0S03 temp: 38.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: HM500JJ
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000VM002-1ET162
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5900
serial: <filter> fw-rev: 3202 scheme: MBR
ID-1: / raw-size: 463.89 GiB size: 463.89 GiB (100.00%)
used: 65.15 GiB (14.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 463.89 GiB size: 463.89 GiB (100.00%)
ID-4: /var/log raw-size: 463.89 GiB size: 463.89 GiB (100.00%)
ID-5: /var/tmp raw-size: 463.89 GiB size: 463.89 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.59 GiB used: 1.73 GiB (14.9%)
ID-2: swap-2 type: partition size: 12.75 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 49.8 C mobo: N/A gpu: amdgpu temp: 39.0 C
Memory: total: 12 GiB available: 11.59 GiB used: 8.85 GiB (76.4%)
Processes: 420 Power: uptime: 12h 11m states: freeze,mem,disk
reboot, suspend, test_resume image: 4.63 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2019 libs: 559 tools: octopi,pamac,paru
Compilers: gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.23-1):
System install date:     2024-02-08
Last full system update: 2024-04-02
Failed units:            NetworkManager-wait-online.service nmb.service
Ty everyone. <3
  • ONE issue per topic.
    Please. :slight_smile:
Sorry the real issue is the one about the browsers the other two things are mostly like general comments in this context.
I edited the post a bit more. I can edit it even more to remove all the reference to the other two things if needed. ty.
