Browser opening issue
brave >> brave_error.txt
[14963:14963:0218/201840.979103:ERROR:policy_logger.cc(156)] :components/enterprise/browser/controller/chrome_
browser_cloud_management_controller.cc(161) Cloud management controller initialization aborted as CBCM is not
enabled. Please use the `--enable-chrome-browser-cloud-management` command line flag to enable it if you are n
ot using the official Google Chrome build.
[15015:15015:0218/201842.084759:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15015:15015:0218/201842.088832:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
rofileH264ConstrainedBaseline and entrypoint VAEntrypointVLD
[15015:15015:0218/201842.088996:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15015:15015:0218/201842.089116:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
rofileH264Main and entrypoint VAEntrypointVLD
[15015:15015:0218/201842.089208:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15015:15015:0218/201842.089289:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
rofileH264High and entrypoint VAEntrypointVLD
[14963:14963:0218/201843.567547:ERROR:gpu_process_host.cc(992)] GPU process exited unexpectedly: exit_code=139
[15165:15165:0218/201843.897621:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15165:15165:0218/201843.901268:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15165:15165:0218/201843.901535:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15165:15165:0218/201843.902755:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15165:15165:0218/201843.904239:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15165:15165:0218/201843.904565:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[14963:14963:0218/201844.639938:ERROR:gpu_process_host.cc(992)] GPU process exited unexpectedly: exit_code=139
[15195:15195:0218/201844.860131:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15195:15195:0218/201844.860535:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15195:15195:0218/201844.860800:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15195:15195:0218/201844.861122:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15195:15195:0218/201844.861220:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15195:15195:0218/201844.861328:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[14963:14963:0218/201845.934944:ERROR:gpu_process_host.cc(992)] GPU process exited unexpectedly: exit_code=139
[15230:15230:0218/201846.108006:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15230:15230:0218/201846.108158:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15230:15230:0218/201846.108260:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15230:15230:0218/201846.108340:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15230:15230:0218/201846.108414:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15230:15230:0218/201846.108483:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[14963:14963:0218/201846.806951:ERROR:gpu_process_host.cc(992)] GPU process exited unexpectedly: exit_code=139
[15255:15255:0218/201846.968627:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15255:15255:0218/201846.968832:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15255:15255:0218/201846.969028:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15255:15255:0218/201846.969139:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15255:15255:0218/201846.969258:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15255:15255:0218/201846.969393:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[14963:14963:0218/201847.898113:ERROR:gpu_process_host.cc(992)] GPU process exited unexpectedly: exit_code=139
[15285:15285:0218/201848.061958:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15285:15285:0218/201848.062101:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15285:15285:0218/201848.062192:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15285:15285:0218/201848.062260:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15285:15285:0218/201848.062334:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15285:15285:0218/201848.062404:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[14963:14963:0218/201848.737539:ERROR:gpu_process_host.cc(992)] GPU process exited unexpectedly: exit_code=139
[15308:15308:0218/201848.854485:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15308:15308:0218/201848.854692:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15308:15308:0218/201848.854793:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15308:15308:0218/201848.854862:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15308:15308:0218/201848.854935:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15308:15308:0218/201848.855003:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[14963:14963:0218/201849.110275:ERROR:sharing_service.cc(221)] Device registration failed with fatal error
[14963:14963:0218/201849.563051:ERROR:gpu_process_host.cc(992)] GPU process exited unexpectedly: exit_code=139
[15330:15330:0218/201849.657805:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15330:15330:0218/201849.658013:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15330:15330:0218/201849.658221:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15330:15330:0218/201849.658567:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15330:15330:0218/201849.658724:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15330:15330:0218/201849.658840:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[14963:14963:0218/201850.243727:ERROR:gpu_process_host.cc(992)] GPU process exited unexpectedly: exit_code=139
[15351:15351:0218/201850.335485:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15351:15351:0218/201850.335687:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15351:15351:0218/201850.335823:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15351:15351:0218/201850.335921:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[15351:15351:0218/201850.336019:ERROR:vaapi_wrapper.cc(1213)] Empty codec maximum resolution
[15351:15351:0218/201850.336114:ERROR:vaapi_wrapper.cc(1122)] FillProfileInfo_Locked failed for va_profile VAP
[14963:14963:0218/201851.356507:ERROR:gpu_process_host.cc(992)] GPU process exited unexpectedly: exit_code=139
[14963:14963:0218/201851.356538:FATAL:gpu_data_manager_impl_private.cc(448)] GPU process isn't usable. Goodbye
[0218/201851.384169:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.384331:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.386425:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.389709:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.399868:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.400146:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.404039:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.404184:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.405550:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.405915:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.406726:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.406865:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.407700:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.408475:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.408644:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.408770:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.408882:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.408990:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.409094:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.409227:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.409351:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.409889:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.410000:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.410105:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.410216:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.410320:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.410426:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.410536:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.410681:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.410789:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.410991:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.411235:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.411337:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.411437:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.411557:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0218/201851.412561:ERROR:elf_dynamic_array_reader.h(64)] tag not found
fish: Job 1, 'brave >> brave_error.txt' terminated by signal SIGTRAP (Trace or breakpoint trap)
Follow the template please. :slightly_smiling_face: Always provide your garuda-inxi when asking for help on forum for anything. Even general advice.
Try to launch the browser with,
brave --disable-gpu
flag. If this works then this is likely a upstream chrome bug I faced a while ago as well. Not sure what version of chrome brave uses but this has been patched in updates.
