Brigthness after sleep is not working
Brightness slider is working as intended until computer wakes up from sleep. then screen is dimmed(says 0%) and the slider is not working anymore, i need to restart to have normal brighness again..
Kernel: 6.4.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=e31445d3-aaf3-44db-9a4b-86c5a54c8b7c rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
UEFI: American Megatrends LLC. v: F37 date: 12/26/2022
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3599 high: 3600 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3588 9: 3600 10: 3600 11: 3600
12: 3600 13: 3600 14: 3600 15: 3600 16: 3600 bogomips: 114983
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASUSTeK
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0b:00.0 chip-ID: 1002:73bf
Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.2:5
chip-ID: 0c45:8006 class-ID: 0301
Device-3: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.3:6
chip-ID: 046d:081b class-ID: 0102 serial: <filter>
s-diag: 777mm (30.58")
Monitor-1: DP-3 mapped: DisplayPort-2 model: LG (GoldStar) ULTRAGEAR
serial: <filter> built: 2021 res: 2560x1440 hz: 165 dpi: 93 gamma: 1.2
max: 2560x1440 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon RX 6900 XT (navi21
LLVM 15.0.7 DRM 3.52 6.4.3-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.4.3-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 14.55 TiB used: 11.34 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Western Digital model: WD BLACK
SN850X HS 2000GB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 620311WD
temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SKC2500M81000G
lanes: 4 tech: SSD serial: <filter> fw-rev: S7780102 temp: 33.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS200T2B0A-00SM50
tech: SSD serial: <filter> fw-rev: 00WD scheme: GPT
model: WD1002FAEX-00Z3A0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD6002FRYZ-01WD5B0 size: 5.46 TiB block-size: physical: 4096 B
fw-rev: 1M02 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD10EALX-009BA0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1H15
ID-7: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD30EFRX-68EUZN0 size: 2.73 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 11.34 GiB (0.6%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
used: 11.34 GiB (0.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
System Temperatures: cpu: 35.8 C mobo: 28.0 C gpu: amdgpu temp: 35.0 C
mem: 32.0 C
Processes: 349 Uptime: 51m wakeups: 7 Memory: total: 16 GiB
available: 15.54 GiB used: 3.65 GiB (23.5%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
pm: pacman pkgs: 1834 libs: 544 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
head: cannot open '/var/log/pacman.log' for reading: No such file or directory
System install date:
Last full system update: 2023-07-14
There are many hiccups with EDIT [Brightness and] Night Color in Plasma. I myself experience some.
Just search on bugs.kde.org and you'll see a list: Bug List
One that may be related but the guy doesn't need to reboot:
https://bugs.kde.org/show_bug.cgi?id=461657
ah.. i also use nightmode when i read lots of stuff, and that works as it should.. well, i hope bugs will get fixed..
Oops sorry, I wrote "night color" but I meant "brightness AND night color". :smiley:
Yes, I too am having this issue. I posted about it on the link below, thought it was maybe caused by the ‘Active Blur Wallpaper’ plugin, but alas, that was not true. The issue is so annoying.
Hmm, one or two times goes into sleep and wakes up with brightness normal, then it wakes up with brightness zero, screen dimmed. when i go into monitor settings, i noticed that brightness is zero. windows never changed my monitor settings like that hahaha, so now at least i know what is the deal here, and how to correct dimmed screen without restarting computer..
