since recently I noticed a issue where at random moments my computer enters a infinite loop and completely freezes where the only way to get it out if it is by hard turning of the computer.
it mostly enters the loop while playing back a sound effect, with which I can also consistently make it brick on command by:
- opening a program which has a save file or export file dialog(gimp for example)
- going to the file name area(save as/export as).
- pressing the left arrow key on the keyboard rapidly until at the beginning of the name/text
- pressing it a few more times, it will play a sound effect for the end or selection or area thing indicating you can’t go further back.
- if not yet triggered then press the left arrow key a few times rapidly which should do the trick.
- it will now very long play that soundeffect in a “endless” loop, the screen and input also all will be stuck, some times it is possible to make the mouse move or to make one key combo pass, though that has to be done at a lucky moment and can take several minutes.
- to get out of it, I need to hard shut down the laptop
next to that, I also have encountered it rarely in other cases. for example when watching a video online in fullscreen and closing my laptop lid, after that opening and starting it again after which around a minute later it froze in a loop again
Note:
I looked into other posts, they all were somewhat different with when they happened and such, though it is realistic that they are related, I will test methods suggested there.
the main difference(other than me not using a nvidia gpu) is that in this case I have a way to reproduce it on command, which might be usefull, especially if it happens to be related to the audio or graphics drivers or such instead of the kernel, might be usefull as it gives a possibility to find out what causes it especially since the new versions of garuda linux are in early testing(note this problem never happened, but when it began it kept happening, so can’t say if it is in the new test versions as that would also require accidentally hitting whatever thing triggers this bug.
now I will try some things people suggested:
- I will try different kernels soon, as well as re-install updates
- auto-cpufreq, schedutil governor setting, cpupower set peformance governor
- trying garuda-update again just in case I happened to have a package which had a bug(note info bellow is after rolling back to a previous snapshot from before i started noticing the issues, still the same issues do still happen, so either they where there for longer or are from something which isn’t rolled back), not directly because i saw it mentioned, but more as a common sense thing, after all garuda is based on arch, so rolling and bleeding edge, meaning it is realistic that once in a while a package with a bug might show up for a while before it is patched.
if any of those methods or something else where I know a direction to what fixed it, fixes it, then I obviously also let it know here.
still if anyone has any other suggestions/ideas for what causes the problem then I would love to know it.
also how would I properly debug such issues, now and in the future.
as in are there special tools for finding where the issue is and roughly what it is/may be.
especially in cases like this where I don’t yet know in what software it happens, and in this case also as I have to hard shut it down, many normal forms of logs might not work properly as they can’t save the final changes(unless lucky)
(system setup) output of garuda-inxi:
Kernel: 6.13.3-arch1-1-znver2 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver2
root=UUID=e52b3504-7e79-4f5e-b76f-27d045825e8f rw rootflags=subvol=@
Desktop: KDE Plasma v: ERR-101 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: LENOVO product: 81YM v: IdeaPad 5 14ARE05
serial: <filter> Chassis: type: 10 v: IdeaPad 5 14ARE05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
part-nu: LENOVO_MT_81YM_BU_idea_FM_IdeaPad 5 14ARE05
uuid: 17da49a0-c1a5-11ea-8105-7c8ae1443d02 UEFI: LENOVO v: DTCN27WW(V1.13)
date: 05/30/2022
ID-1: BAT1 charge: 49.8 Wh (100.0%) condition: 49.8/56.5 Wh (88.2%)
volts: 12.9 min: 11.6 model: 0x43 0x65 0x6C 0x78 0x70 0x72 0x74 0x00 0x32
0x30 0x31 0x4C 0x31 0x39 0x43 0x33 0x50 0x46 type: Li-ion serial: <filter>
status: full cycles: 188
Info: model: AMD Ryzen 5 4500U with Radeon Graphics socket: FP6 bits: 64
type: MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
microcode: 0x860010D
Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 smt: <unsupported> cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2375 min/max: 1400/2375 boost: enabled
base/boost: 2375/4000 scaling: driver: acpi-cpufreq governor: performance
volts: 1.2 V ext-clock: 100 MHz cores: 1: 2375 2: 2375 3: 2375 4: 2375
5: 2375 6: 2375 bogomips: 28444
Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 41.0 C
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 174f:244c
Display: unspecified server: X.Org v: 24.1.5 with: Xwayland v: 24.1.5
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: AU Optronics 0x408d built: 2019 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
renoir LLVM 19.1.7 DRM 3.60 6.13.3-arch1-1-znver2) device-ID: 1002:1636
memory: 1.95 GiB unified: no
API: Vulkan v: 1.4.303 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1636
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: Lenovo driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.3-arch1-1-znver2 status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.7 status: n/a (root, process) with:
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 8087:0029
Local Storage: total: 1.4 TiB used: 445.83 GiB (31.2%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung
model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: AL2QFXV7 temp: 37.9 C scheme: GPT
SMART: yes health: PASSED on: 154d 14h cycles: 512,959
read-units: 64,640,903 [33.0 TB] written-units: 45,617,067 [23.3 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Lexar model: SSD NM620 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 12544 temp: 37.9 C scheme: GPT
SMART: yes health: PASSED on: 32d 15h cycles: 7,251
read-units: 6,799,065 [3.48 TB] written-units: 3,017,707 [1.54 TB]
ID-1: / raw-size: 264.99 GiB size: 264.99 GiB (100.00%)
used: 178.96 GiB (67.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p4
maj-min: 259:3
used: 53.4 MiB (20.9%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:5
ID-3: /home raw-size: 264.99 GiB size: 264.99 GiB (100.00%)
maj-min: 259:3
ID-4: /var/log raw-size: 264.99 GiB size: 264.99 GiB (100.00%)
maj-min: 259:3
ID-5: /var/tmp raw-size: 264.99 GiB size: 264.99 GiB (100.00%)
maj-min: 259:3
ID-1: swap-1 type: zram size: 13.52 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 6
System Temperatures: cpu: 47.4 C mobo: N/A gpu: amdgpu temp: 40.0 C
Memory: total: 16 GiB note: est. available: 13.52 GiB used: 2.96 GiB (21.9%)
Processes: 311 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
image: 5.4 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: 2464 pm: pacman pkgs: 2440 libs: 639 tools: octopi,paru
pm: flatpak pkgs: 24 Compilers: clang: 19.1.7 gcc: 14.2.1
Shell: garuda-inxi (sudo) default: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2024-11-16
Last full system update: 2025-02-19
Windows dual boot: Yes
please note, that I just reverted back to a recent snapshot as the problems seemed to have begun after a update with garuda-update, and updating it again in the same ways gave errors with compatibility issues surrounding electron29, I will soon try to upgrade again as there where never packages, but right now you see a reverted state(reverted with snapper)(which still has the same issues)
