Brave PWA icons grouped with Brave Instead of Having their own icon
Kernel: 5.18.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=d74a47ce-c071-4684-aa64-3eb5cafdaff7 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: ASRock model: B550 Phantom Gaming-ITX/ax
serial: <superuser required> UEFI: American Megatrends LLC. v: P2.20
date: 08/05/2021
Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80)
stepping: 0 microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2990 high: 2994 min/max: 1400/4268 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2991 2: 2994
3: 2994 4: 2991 5: 2992 6: 2969 7: 2994 8: 2991 9: 2992 10: 2988 11: 2994
12: 2993 bogomips: 86242
STIBP: always-on, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f06 class-ID: 0300
Device-2: Creative Live! Cam Sync 1080p type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1.1:4 chip-ID: 041e:409f
Screen-1: 0 s-res: 1921x2160 s-dpi: 80 s-size: 610x686mm (24.02x27.01")
s-diag: 918mm (36.14")
Monitor-1: DP-2 pos: primary,bottom-l res: 1920x1080 dpi: 82
Monitor-2: HDMI-0 pos: top-right res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 3-1.1:4 v: kernel chip-ID: 041e:409f pcie:
gen: 3 class-ID: 0102 speed: 8 GT/s serial: <filter> lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3
Device-4: Creative Live! Cam Sync 1080p type: USB
Device-5: C-Media Q9-1 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 3-1.2:5 chip-ID: 0d8c:0135 class-ID: 0300
Device-6: Corsair HS70 Pro Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.4:6 chip-ID: 1b1c:0a4f
Sound Server-1: ALSA v: k5.18.9-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.54 running: yes
Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
bus-ID: 3-9:9 chip-ID: 8087:0029 class-ID: e001
address: <filter>
Local Storage: total: 1.87 TiB used: 20 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 731030WD temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 953.87 GiB block-size: physical: 512 B
rev: SN07151 temp: 41.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: PNY model: USB 2.0 FD
size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 442.5 GiB size: 442.5 GiB (100.00%) used: 20 GiB (4.5%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
ID-2: /boot/efi raw-size: 750 MiB size: 748.5 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 442.5 GiB size: 442.5 GiB (100.00%)
used: 20 GiB (4.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
ID-4: /var/log raw-size: 442.5 GiB size: 442.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 442.5 GiB size: 442.5 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.49 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 355 Uptime: 1h 5m wakeups: 0 Memory: 15.49 GiB
used: 4.87 GiB (31.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1881
lib: 512 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date:     2022-07-06
Last full system update: 2022-07-07 ↻
Hello! I've searched and searched with not really any luck with anything from this year or last year that works... I use Brave (Chromium based) to create PWA's of a lot of my favorite sites (Garuda Forum is one of them; I installed it, but others I click the three lines, click "More Tools", then click "Create Shortcut", and check the box "Open as Window"), and when I open them, the icons-only taskbar is grouping them with the standard Brave browser icon instead of them having their own icon as I've had work in the past. I've attempted to add flags as I saw mentioned in one post, I've changed icons to Breeze Dark (which worked in the past when I had this issue), and SO many other icons, but NOTHING will allow these icons to have their own! Is there a default baked into Garuda that forces the icons to be grouped together instead of having their own? Or is this a Plasma issue? If I left anything out, it wasn't intentional, just let me know! Still trying to learn. :slight_smile:
I forgot to attach this. This is what it does to the PWA icons instead of them having their own icon.
Maybe this one? I went through it very quickly, but despite the title and many mentioning of Wayland, it is also about Brave and X11:
Yeah I ran across that, but that is from 2016, though it's the same issue. I've about torn my brain from my head trying to figure this out. It's the only thing from me having the perfect desktop!! Lol
Edit: I just saw the comments from 2022. Thank you!! I guess I'll have to wait until they send a fix down the pipeline.
I saw it was old, but it was reopened about one month ago.
Edit: I just saw your edit :wink:
Edit2: I see so many different brave packages and versions in the AUR: brave, brave-git, brave-bin, brave-beta-bin, brave-nightly-bin, brave-dev-git !!!
If it is really so important, maybe you could try some of them, maybe one older and one newer.
It should definitely be that KDE bug, but you never can say...
