Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1a0f69c8-e267-445d-86bb-fb7447e71309 rw rootflags=subvol=@
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: LENOVO product: 20FMS1H600 v: ThinkPad T460
Mobo: LENOVO model: 20FMS1H600 v: SDK0J40705 WIN
serial: <superuser required> UEFI-[Legacy]: LENOVO v: R06ET71W (1.45 )
date: 02/21/2022
ID-1: BAT0 charge: 18.4 Wh (100.0%) condition: 18.4/23.2 Wh (79.2%)
volts: 12.3 min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
status: full
ID-2: BAT1 charge: 9.4 Wh (53.7%) condition: 17.5/23.5 Wh (74.4%)
volts: 11.4 min: 11.4 model: LGC 45N1127 type: Li-ion serial: <filter>
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1300 high: 2500 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 2500
bogomips: 19999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
compositor: gnome-shell driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1482 built: 2012 res: 1600x900
hz: 60 dpi: 132 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1600x900
missing.
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
Local Storage: total: 931.51 GiB used: 51.05 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
type: SSD serial: <filter> rev: 04RL scheme: MBR
used: 51.05 GiB (5.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 15.04 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 33.0 C pch: 31.5 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 257 Uptime: 1h 4m wakeups: 1 Memory: 15.04 GiB
used: 3.84 GiB (25.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1338
libs: 365 tools: pamac,paru Shell: fish v: 3.5.1 running-in: gnome-terminal
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-14
Last full system update: 2022-11-14 ↻
Snapshots: Snapper (maybe)
Hallo zusammen, möchte mich erstmal kurz vorstellen. Ich heiße Susanne und arbeite seit ca. 2 Jahren mit verschiedenen Linux Distros. Derzeitig mit Garuda und Manjaro. Ich habe mir Garuda Gnome installiert und alles läuft soweit super. Nachdem ich Boxen VM installiert habe, friert dieser permanent ein. Ich kann keine Distro testen etc. Ich habe bereits auch VM 7 installiert, dort erscheint auch ein Fehlercode 1908-rc. Warum funktioniert Boxen unter Gnome nicht? Weiß jemand ein Tipp?
Grüße Susanne
