Borked my KDE please help
I installed Plank and ran a command xprop -remove _KDE_NET_WM_SHADOW
Now I get a black screen with mouse cursor after logging in.
Please help, how do I fix this.
Inixi and journalctl scrrenshots:
Can't post pictures here it says pls resize pixels too large.
I think you should restore the latest working snapshot...
It didn't work, so I wiped root partition and reinstalled Garuda, issue persists after fresh install on old Home directory. Something has changed in my home directory, it survived countless distro hopping, i might have to wipe it :sob::sob::sob:
Let me guess: you don't backup home directory, do you? :wink:
Before wiping, boot to a tty and create a new user.
Then, if working, you can move carefully the configurations.
If you can't boot to a tty, chroot from a live USB.
