Booting in emergency mode after external HDD partitioning
Hello to everybody,
yesterday I wanted to move some files to an old external HDD. Before moving the files, I deleted any existing partitions and changed the filesystem to btrfs using KDE Partition Manager. I formatted it by changing the drive name to Data_2 and mount point to / run / media / andrea / Data_2.
Everything seemed to work fine, so I repeated the whole operation with another external HDD, calling it Data_3 and mount point / run / media / andrea / Data_3.
No error message, the PC shutdown went smoothly.
Today, when I turn on my PC, I notice that the startup is particularly slow. After more than a minute and a half (usually it takes no more than 15 seconds) the system goes into emergency mode:
You are in emergency mode. After logging in, type “journal -xb” to view system logs, “systemctl reboot” to reboot, “systemctl default” or “exit” to boot into default mode.
Give root password for maintenance
(or press Control-D to continue):
Then I reboot the system, I try to use another kernel (linux-lts) but nothing changes. So I boot from a timeshift snapshop. This time, finally, the boot is successful.
I have made multiple booting attempts, checking the output of journalctl -b -1 each time.
This is an example of a suspicious error:
ago 11 21:55:15 andrea-vyper kernel: audit: type=1131 audit(1628711715.184:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 11 21:56:39 andrea-vyper systemd[1]: dev-sda2.device: Job dev-sda2.device/start timed out.
ago 11 21:56:39 andrea-vyper systemd[1]: Timed out waiting for device /dev/sda2.
ago 11 21:56:39 andrea-vyper systemd[1]: Dependency failed for /run/media/andrea/New Volumentfs.
ago 11 21:56:39 andrea-vyper systemd[1]: Dependency failed for Local File Systems.
ago 11 21:56:39 andrea-vyper systemd[1]: local-fs.target: Job local-fs.target/start failed with result 'dependency'.
ago 11 21:56:39 andrea-vyper systemd[1]: local-fs.target: Triggering OnFailure= dependencies.
ago 11 21:56:39 andrea-vyper systemd[1]: run-media-andrea-New\x20Volumentfs.mount: Job run-media-andrea-New\x20Volumentfs.mount/start failed with result 'dependency'.
ago 11 21:56:39 andrea-vyper systemd[1]: dev-sda2.device: Job dev-sda2.device/start failed with result 'timeout'.
I am sure that, in previous boot attempts, the output of journalctl -b -1 contained the same type of error referring to the Data_2 and Data_3 drives.
Content of /etc/fstab:
UUID=59AE-85F1                            /boot/efi      vfat    umask=0077 0 2
UUID=4967c5d8-4aa7-40ae-a1a9-6ab7ceab2b77 /              btrfs   subvol=/@,defaults,noatime,space_cache,autodefrag,compress=zstd 0 1
UUID=4967c5d8-4aa7-40ae-a1a9-6ab7ceab2b77 /root          btrfs   subvol=/@root,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=4967c5d8-4aa7-40ae-a1a9-6ab7ceab2b77 /srv           btrfs   subvol=/@srv,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=4967c5d8-4aa7-40ae-a1a9-6ab7ceab2b77 /var/cache     btrfs   subvol=/@cache,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=4967c5d8-4aa7-40ae-a1a9-6ab7ceab2b77 /var/log       btrfs   subvol=/@log,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=4967c5d8-4aa7-40ae-a1a9-6ab7ceab2b77 /var/tmp       btrfs   subvol=/@tmp,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=1a453e0b-5ce4-411d-8fc0-5730f4b4d12c /home          btrfs   defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=1460dc6b-7e5e-4150-8a3c-8a783f9edfb9 swap           swap    defaults,noatime 0 0
Output of blkid:
/dev/nvme0n1p3: UUID="1a453e0b-5ce4-411d-8fc0-5730f4b4d12c" UUID_SUB="fc39b122-e76f-45ab-8c6f-f62684e9e9d9" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="5d1e8d28-629c-c349-bd7c-382f8e94cec7"
/dev/nvme0n1p1: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="59AE-85F1" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="1b84684d-a7f2-8148-8d00-c97c79f04cdd"
/dev/nvme0n1p4: UUID="1460dc6b-7e5e-4150-8a3c-8a783f9edfb9" TYPE="swap" PARTUUID="b5acb501-bd1b-2047-890e-51d4f73e1c99"
/dev/nvme0n1p2: UUID="4967c5d8-4aa7-40ae-a1a9-6ab7ceab2b77" UUID_SUB="6cebb0de-8d4a-4205-a98f-c3b515d2bb31" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="47087b88-e980-f147-a2c5-9d143e55b120"
/dev/sda1: LABEL="Data" UUID="e6419550-0cc6-4eb3-8dfb-8941ca1a00ac" UUID_SUB="64b7547a-bdef-4ec3-b7c8-6b8f2d9cb55a" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="761ebed0-7a95-3e46-a5a0-95739e7c628e"
/dev/zram0: LABEL="zram0" UUID="973e1e00-c771-4d3d-b625-7701217ca1f9" TYPE="swap"
Output of lsblk:
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda           8:0    0 931,5G  0 disk
└─sda1        8:1    0 931,5G  0 part /run/media/andrea/Data
zram0       254:0    0  31,2G  0 disk [SWAP]
nvme0n1     259:0    0 465,8G  0 disk
├─nvme0n1p1 259:1    0   513M  0 part /boot/efi
├─nvme0n1p2 259:2    0   100G  0 part /run/timeshift/backup
│                                     /var/tmp
│                                     /var/log
│                                     /var/cache
│                                     /srv
│                                     /root
├─nvme0n1p3 259:3    0 317,3G  0 part /home
└─nvme0n1p4 259:4    0    48G  0 part [SWAP]
Is booting into emergency mode caused by these errors? How can I go about solving?
Thank you in advance for your help!
Without any real information my best guess is you have permanent mounts in /etc/fstab or systemd units to the old locations in /run/media which isn't what you want. If that is the case, try removing those and see if your system boots.
Wrong file. You are investigating your failed system, not your working snapshot :wink:
Find and browse your broken (old current) snapshot in Timeshift or in File Manager at /run/timeshift/backup/.
You haven’t even said what DE you run.
There is an intro message in each new topic 1st post. Do you read it, or just … delete (Nah! It’s not for me…)?
Is it the hot summer? :man_shrugging:
