Flashing stops only after clicking outside of the effected window. Reappears if the effected window is moved again but not if you simply working inside the window without moving it around. Installing Better Blur doesn’t help. So i have an extra click latency to stop the flashing. Will it be resolved?
Kernel: 6.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=64c5885f-f1e8-4d9b-b0a0-db6572565fe0 rw rootflags=subvol=@
loglevel=3 quiet
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
wm: kwin_wayland tools: avail: lxlock vt: 1 dm: SDDM Distro: Garuda
Type: Desktop Mobo: ASRock model: B450 Gaming-ITX/ac
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends v: P10.43 date: 06/25/2025
Device-1: hidpp_battery_0 model: Logitech PRO 2 LIGHTSPEED serial: <filter>
charge: 52% rechargeable: yes status: discharging
Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 3
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA500014
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4210 min/max: 480/4980 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4210 2: 4210 3: 4210
4: 4210 5: 4210 6: 4210 7: 4210 8: 4210 9: 4210 10: 4210 11: 4210 12: 4210
bogomips: 100807
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
XT/6600M] vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1,
Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Dell S2719DGF serial: <filter> built: 2019 res:
mode: 2560x1440 hz: 144 scale: 175% (1.75) to: 1463x823 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 21.1.5 DRM 3.64 6.17.9-zen1-1-zen) device-ID: 1002:73ff
API: Vulkan v: 1.4.328 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 25.2.7-arch1.1
device-ID: 1002:73ff surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.5 256 bits) driver: mesa llvmpipe v: 25.2.7-arch1.1 (LLVM
21.1.5) device-ID: 10005:0000 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: amdgpu_top wl: wayland-info
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
bus-ID: 0d:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 0d:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Harman JBL Quantum TWS driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
chip-ID: 0ecb:208a class-ID: 0300 serial: <filter>
API: ALSA v: k6.17.9-zen1-1-zen status: kernel-api tools: N/A
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 0a:00.0
IF: wlp10s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 0b:00.0
IF: enp11s0 state: down mac: <filter>
IF-ID-1: enp13s0f4u2 state: unknown speed: -1 duplex: unknown
mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0aa7
Device-2: Xiaomi Mi/Redmi series (RNDIS) driver: rndis_host v: kernel
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3
chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
Local Storage: total: 931.51 GiB used: 394.03 GiB (42.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 800
lanes: 4 tech: SSD serial: <filter> fw-rev: V1122B0 temp: 37.9 C
used: 394.03 GiB (42.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.21 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
mem: 44.0 C
Memory: total: 32 GiB available: 31.21 GiB used: 3.13 GiB (10.0%)
Processes: 327 Power: uptime: 54m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1594 libs: 417 tools: paru,pikaur,yay
pm: flatpak pkgs: 0 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash
v: 5.3.3 default: fish v: 4.2.1 running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2024-10-21
Garuda release: 240428
Last full system update: 2025-11-29 ↻
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
25/26 checks run in 0.90 seconds ⌛
Powered by garuda-health 🦅
