Bluetooth w/ external speaker failing w/ HW error?
Post garuda-update, bluetooth now gives (repeatedly until i remove the device):
Feb 26 11:31:47 bit blueman-manager[69627]: blueman-manager 11.31.47 ERROR    Manager:223 error_handler:  Authentication Failed
Feb 26 11:31:47 bit blueman-manager[69627]: Traceback (most recent call last):
Feb 26 11:31:47 bit blueman-manager[69627]:   File "/usr/lib/python3.10/site-packages/blueman/bluez/Base.py", line 78, in callback
Feb 26 11:31:47 bit blueman-manager[69627]:     value = proxy.call_finish(result).unpack()
Feb 26 11:31:47 bit blueman-manager[69627]: gi.repository.GLib.GError: g-io-error-quark: GDBus.Error:org.bluez.Error.AuthenticationFailed: Authentication F
ailed (36)
Feb 26 11:31:49 bit kernel: Bluetooth: hci0: Hardware error 0x0c
Feb 26 11:31:49 bit kernel: Bluetooth: hci0: Retrieving Intel exception info failed (-16)
Feb 26 11:31:50 bit kernel: Bluetooth: hci0: Hardware error 0x0c
Feb 26 11:31:50 bit kernel: Bluetooth: hci0: Retrieving Intel exception info failed (-16)
Feb 26 11:31:52 bit kernel: Bluetooth: hci0: Hardware error 0x0c
Feb 26 11:31:52 bit kernel: Bluetooth: hci0: Retrieving Intel exception info failed (-16)
Feb 26 11:31:53 bit kernel: Bluetooth: hci0: Hardware error 0x0c
Feb 26 11:31:53 bit kernel: Bluetooth: hci0: Retrieving Intel exception info failed (-16)
Feb 26 11:31:55 bit kernel: Bluetooth: hci0: Hardware error 0x0c
Feb 26 11:31:55 bit kernel: Bluetooth: hci0: Retrieving Intel exception info failed (-16)
Feb 26 11:31:56 bit kernel: Bluetooth: hci0: Hardware error 0x0c
Feb 26 11:31:56 bit kernel: Bluetooth: hci0: Retrieving Intel exception info failed (-16)
Feb 26 11:31:58 bit kernel: Bluetooth: hci0: Hardware error 0x0c
Feb 26 11:31:58 bit kernel: Bluetooth: hci0: Retrieving Intel exception info failed (-16)
Feb 26 11:31:59 bit kernel: Bluetooth: hci0: Hardware error 0x0c
Feb 26 11:31:59 bit kernel: Bluetooth: hci0: Retrieving Intel exception info failed (-16)
Feb 26 11:32:01 bit kernel: Bluetooth: hci0: Hardware error 0x0c
Feb 26 11:32:01 bit kernel: Bluetooth: hci0: Retrieving Intel exception info failed (-16)
Feb 26 11:32:07 bit kernel: Bluetooth: hci0: Hardware error 0x0c
Feb 26 11:32:08 bit kernel: Bluetooth: hci0: Retrieving Intel exception info failed (-16)
Feb 26 11:32:08 bit blueman-manager[69627]: blueman-manager 11.32.08 ERROR    Manager:223 error_handler:  Authentication Failed
Feb 26 11:32:08 bit blueman-manager[69627]: Traceback (most recent call last):
Feb 26 11:32:08 bit blueman-manager[69627]:   File "/usr/lib/python3.10/site-packages/blueman/bluez/Base.py", line 78, in callback
  Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=641c7d0e-10b8-42e3-a23d-f70c816cb89a rw [email protected]
    loglevel=3 ibt=off
  Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 2607
    date: 08/14/2020
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3808 high: 4195 min/max: 2200/4208 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3669 2: 3600
    3: 4117 4: 4191 5: 3600 6: 4195 7: 3616 8: 3728 9: 3600 10: 3600 11: 3600
    12: 4182 bogomips: 86242
  Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Micro-Star MSI
    driver: nouveau v: kernel non-free: 525.xx+ status: current (as of 2023-02)
    arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: DP-3 empty: DP-1, DP-2, DVI-I-1, HDMI-A-1 bus-ID: 09:00.0
    chip-ID: 10de:1401 class-ID: 0300 temp: 33.0 C
  Device-2: Anker PowerConf C300 type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 3-4:5 chip-ID: 291a:3361 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.7 compositor: Picom v: git-b700a
    driver: X: loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa
    dri: nouveau gpu: nouveau display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
    s-diag: 987mm (38.84")
  Monitor-1: DP-3 model: Samsung S34J55x serial: <filter> built: 2020
    res: 3440x1440 dpi: 110 gamma: 1.2 size: 797x333mm (31.38x13.11")
    diag: 864mm (34") modes: max: 3440x1440 min: 720x400
  API: OpenGL v: 4.3 Mesa 22.3.6 renderer: NV126 direct-render: Yes
  Device-1: NVIDIA GM206 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel bus-ID: 1-3:2 v: kernel pcie: chip-ID: 047f:c025
    class-ID: 0300 gen: 1 serial: <filter> speed: 2.5 GT/s lanes: 16 link-max:
    gen: 3 speed: 8 GT/s bus-ID: 09:00.1 chip-ID: 10de:0fba class-ID: 0403
    bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Plantronics Plantronics C320-M type: USB
    driver: plantronics,snd-usb-audio,usbhid
  Device-4: Anker PowerConf C300 type: USB driver: snd-usb-audio,uvcvideo
  Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
  Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2526 class-ID: 0280
    lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
    v: 0.8 bus-ID: 3-5:3 chip-ID: 8087:0025 class-ID: e001
  Local Storage: total: 2.74 TiB used: 124.19 GiB (4.4%)
    rev: 2B2QEXM7 temp: 37.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
    type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
    model: DataTraveler 2.0 size: 7.22 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> rev: 1.00
    used: 61.88 GiB (6.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 58.1 C mobo: N/A gpu: nouveau temp: 33.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 896
  Processes: 378 Uptime: 28m wakeups: 0 Memory: 31.26 GiB
  used: 5.3 GiB (17.0%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1513
  libs: 384 tools: pamac,paru Shell: Zsh v: 5.9 running-in: alacritty
  inxi: 3.3.25
Garuda (2.6.15-1):
  System install date:     2022-09-11
  Last full system update: 2023-02-26 ↻
Have you rebooted
Yes, but i dont mind trying again .. in case ive remember wrongly! :wink:
yep .. no go: immediately begins to attempt to do whatever it is trying to do and generates those errors.
in fact, i think it continuously trying and im thinking of shutting it off so it [the BT service i assume] doesnt waste the time trying and trying ...
my BT icon in my i3bar is flashing and with a journal this is my evidence it is continuously trying.
disabled the bluetooth.service until i can deal with it.
