Bluetooth not working properly
Ayye, i got a problem with Bluetooth on my Laptop with KDE Dragonized (kernel 5.11.1-zen1-zen-1) when connecting to a bluetooth device, it causes problems with the bluetooth service itself as well as the wifi -> bluetooth randomly breaks and restarts and also sometimes affecting wifi to restart as well
on other distros it works without any problems (ubuntu, budgie, lubuntu, mate ...)
if any hardware specific information is needed, please tell me how i can provide it
System:    Kernel: 5.11.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
           parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9b5a94e9-9e02-48e4-a927-d3eb58423e22
           rw [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
           systemd.unified_cgroup_hierarchy=1 resume=UUID=c80ba066-51f7-47c4-b5a0-e87b608a777a loglevel=3
           Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: Packard Bell product: Easynote ENTF71BM v: V1.10 serial: <filter> Chassis:
           type: 10 serial: <filter>
           Mobo: Packard Bell model: Easynote ENTF71BM v: V1.10 serial: <filter> UEFI: Packard Bell
           v: 1.10 date: 09/15/2015
Battery:   ID-1: BAT1 charge: 54.1 Wh (100.0%) condition: 54.1/53.4 Wh (101.4%) volts: 17.1 min: 15.0
           model: SANYO PABAS0241231 type: Li-ion serial: <filter> status: Full
CPU:       Info: Dual Core model: Intel Celeron N2830 bits: 64 type: MCP arch: Silvermont family: 6
           model-id: 37 (55) stepping: 8 microcode: 838 cache: L2: 1024 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8666
           Speed: 2015 MHz min/max: 500/2416 MHz Core speeds (MHz): 1: 2015 2: 2190
           Type: spec_store_bypass status: Not affected
           mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics:  Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
           vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0f31
           Device-2: Chicony VGA Webcam type: USB driver: uvcvideo bus-ID: 1-4:3 chip-ID: 04f2:b47f
           Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel
           Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 99 size: 350x190mm (13.8x7.5") diag: 398mm (15.7")
           OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 20.3.4 compat-v: 3.0
           direct render: Yes
Audio:     Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
           vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
           chip-ID: 8086:0f04 class-ID: 0403
           Sound Server-1: ALSA v: k5.11.1-zen1-1-zen running: yes
           Sound Server-4: PipeWire v: 0.3.24 running: no
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
           driver: r8169 v: kernel port: 1000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
           Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Foxconn
           driver: ath9k v: kernel port: 1000 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
Bluetooth: Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 1-2.1:17 chip-ID: 0489:e078
           Report: ID: hci0 state: down bt-service: enabled, running address: <filter>
Drives:    Local Storage: total: 465.76 GiB used: 10.8 GiB (2.3%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD5000LPVX-22V0TT0 size: 465.76 GiB
           block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter>
           rev: 1A01 scheme: GPT
Partition: ID-1: / raw-size: 457.32 GiB size: 457.32 GiB (100.00%) used: 10.8 GiB (2.4%) fs: btrfs
           dev: /dev/sda2 maj-min: 8:2
           ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 546 KiB (0.2%) fs: vfat
           dev: /dev/sda1 maj-min: 8:1
           ID-3: /home raw-size: 457.32 GiB size: 457.32 GiB (100.00%) used: 10.8 GiB (2.4%) fs: btrfs
           ID-4: /var/log raw-size: 457.32 GiB size: 457.32 GiB (100.00%) used: 10.8 GiB (2.4%) fs: btrfs
           ID-5: /var/tmp raw-size: 457.32 GiB size: 457.32 GiB (100.00%) used: 10.8 GiB (2.4%) fs: btrfs
Swap:      Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
           ID-1: swap-1 type: partition size: 8.19 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
           maj-min: 8:3
           ID-2: swap-2 type: zram size: 1.86 GiB used: 5.2 MiB (0.3%) priority: 32767 dev: /dev/zram0
           ID-3: swap-3 type: zram size: 1.86 GiB used: 5 MiB (0.3%) priority: 32767 dev: /dev/zram1
Sensors:   System Temperatures: cpu: 52.0 C mobo: N/A
Info:      Processes: 184 Uptime: 1h 04m wakeups: 1 Memory: 3.72 GiB used: 2.26 GiB (60.8%) Init: systemd
           v: 247 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1201 lib: 301
           Shell: fish v: 3.2.0 running-in: konsole inxi: 3.3.03
Welcome Sashiro :wave:
To post sys info, go into terminal and enter inxi -Fxxxza then post as text, please
Edit: Beaten to it! :rofl:
already done it, updated the main post
Found this, haven't got correct fonts installed to check further, I'm afraid
https://wiki.archlinux.org/index.php/Bluetooth
There are three threads on Foxconn Hon Hai, but I don't have the correct fonts installed, to check further.
https://wiki.archlinux.org/index.php?search=foxconn+hon+hai&title=Special%3ASearch&go=Go
Regardless of your problem, the Zen kernel looks a bit antiquated.
Jep, use
upd
in terminal.
Have you tried [FN] + [WiFi]? Sign out and sign back in.
@Stroke_Finger didn't find anything that could fix the problem
@SGS already did that, system is up-to-date with latest iso & updates
@sunda i already tried to use different kernels - same issue
(linux-mainline 5.12rc3-1 works like charm (no bluetooth/wifi issue), but it f*cks up my touchpad lol, so cant use it)
also i dort have a WiFi FN option on my laptop
nrhg this frustrates me that Bluetooth doesn't wanna work, because on other distros it does :confused:
and i really wanna stay with garuda forever, because of how awesome it is
Hate to say it, but could you get a USB adapter? :slightly_smiling_face:
haha yeah maybe, or i just stay with wired headphones instead - laptop is pretty old too tho
but its strange that the mainline kernel works, but others not xD
Well, others may be leading edge, but Garuda is bleeding-edge.
Yes, it's a workaround, but it would give you time to sort problems at your leisure.
ohh well nvm i can stay with mainline i see... just have to use [basic] touchpad functions set in bios/uefi instead of [advanced]
ill try to fix it anyway using the latest garuda kernel (the bluetooth issue), and if i find a solution, ill update the post xD
Please! That helps any who come after experiencing similar issues. :slightly_smiling_face:
You have definitely upgraded your Easynote, because 2048 MB DDR3 RAM is clearly not enough for Garuda KDE Dragonized.
In contrast, 1 Gb DDR2 (+ ReadyBoost) is sufficient for Win10
2048 MB DDR3
it actually is 4096 MB ddr3
the insanely strange thing is :'D
with the previous version (the one be4 hawk eagle) didnt really work with my laptop (laggy as hell, wasnt even able to stream 720p videos in firefox because of the stuttering, freezes and laggs)
but with the hawk eagle upgrade... KDE dragonized is WAY faster and more stable than a fresh ubuntu installation, even video streaming (720p) on the new firefox is way smoother than on KDE multimedia (before hawk eagle edition)
Hawk Eagle Dragonized turned my laptop into a time mashine :smiley: another aspect why i love garuda linux, its so fast on a old trashy laptop (even dragonized since hawk eagle)
If you haven't figured it out yet from your description it's pretty obvious this is a kernel issue not a Garuda issue. The reason it likely works on Ubuntu variants is they generally use older kernels. Perhaps they have applied custom patches to their kernels that Garuda does not do. We use the kernels as they come directly from upstream.
Try installing the older LTS kernel if you haven't tested it already. If that doesn't work there's a dozen other kernels you could try.
Good luck.
Thread is deemed abandoned.
Thread is now closed.
PM a mod if you are the OP and wish the issue reopened.
