Hello there
here is the garuda-inxi output
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=cfd2a3ad-b9aa-424e-9138-1465c69be317 rw [email protected]
loglevel=3 ibt=off
wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z68AP-D3 v: N/A serial: N/A Chassis:
type: 3 serial: N/A
Mobo: Gigabyte model: Z68AP-D3 serial: N/A BIOS: Award v: F8
date: 03/21/2012
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
Info: model: Intel Core i5-2500 socket: 478 (1155) note: check bits: 64
type: MCP arch: Sandy Bridge gen: core 2 level: v2 built: 2010-12
process: Intel 32nm family: 6 model-id: 0x2A (42) stepping: 7
microcode: 0x2F
desc: 1x6 MiB
Speed (MHz): avg: 1598 high: 1600 min/max: 1600/3300 base/boost: 3300/4000
scaling: driver: intel_cpufreq governor: schedutil volts: 1.0 V
ext-clock: 100 MHz cores: 1: 1600 2: 1596 3: 1596 4: 1600 bogomips: 26340
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
vendor: Gigabyte driver: i915 v: kernel arch: Gen-6 process: Intel 32nm
built: 2011 ports: active: none off: VGA-2 empty: DP-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0380
Device-2: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
vendor: Gigabyte driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 2
speed: 5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1,VGA-1 empty: DVI-D-1,DVI-D-2 bus-ID: 06:00.0
chip-ID: 1002:683f class-ID: 0300 temp: 37.0 C
Device-3: Arkmicro Webcam Carrefour type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.5:4 chip-ID: 18ec:3299
class-ID: 0102
compositor: kwin_x11 driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: radeonsi,crocus gpu: i915,radeon
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-1 mapped: HDMI-0 pos: right model: Samsung built: 2010
res: 1920x1080 hz: 60 dpi: 305 gamma: 1.4 size: 160x90mm (6.3x3.54")
diag: 801mm (31.5") ratio: 16:9 modes: max: 1360x768 min: 720x400
Monitor-2: VGA-1 mapped: VGA-0 pos: primary,left model: Dell E2211H
serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
Monitor-3: VGA-2 mapped: VGA-1-2 note: disabled size-res: N/A modes:
max: 1024x768 min: 640x480
API: OpenGL v: 4.5 Mesa 22.3.1 renderer: VERDE ( LLVM 14.0.6 DRM 2.50
6.0.12-zen1-1-zen) direct render: Yes
vendor: Gigabyte driver: snd_hda_intel bus-ID: 1-1.5:4 v: kernel
bus-ID: 00:1b.0 chip-ID: 18ec:3299 class-ID: 0102 chip-ID: 8086:1c20
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 2
bus-ID: 06:00.1 chip-ID: 1002:aab0 class-ID: 0403
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
lanes: 1 port: ce00 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
**Bluetooth:**
**Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB**
**driver: btusb v: 0.8 bus-ID: 1-1.3:3 chip-ID: 0a12:0001 class-ID: e001**
**Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>**
Local Storage: total: 2.46 TiB used: 829.44 GiB (33.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3200822A
family: Barracuda 7200.7 and 7200.7 Plus size: 186.31 GiB block-size:
physical: 512 B logical: 512 B speed: 1.5 Gb/s type: N/A serial: <filter>
rev: 3.01 temp: 41 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 316d 1h cycles: 11921
Old-Age: UDMA CRC errors: 1072 alert: Bad cable/connection? Pre-Fail:
reallocated sector: 100 threshold: 36 attribute: Spin_Retry_Count
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500418AS
family: Barracuda 7200.12 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 1.5 Gb/s type: HDD rpm: 7200
serial: <filter> rev: HP35 temp: 38 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 117d 14h cycles: 45549
Pre-Fail: reallocated sector: 100 threshold: 36 attribute: Spin_Retry_Count
model: WD20EADS-00W4B0 family: Caviar Green size: 1.82 TiB block-size:
physical: 512 B logical: 512 B sata: 2.6 speed: 1.5 Gb/s type: N/A
serial: <filter> rev: 0A01 temp: 32 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 55d 11h cycles: 5687
ID-1: / raw-size: 186.31 GiB size: 186.31 GiB (100.00%)
used: 20.74 GiB (11.1%) fs: btrfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 186.31 GiB size: 186.31 GiB (100.00%)
maj-min: 8:1
ID-3: /var/log raw-size: 186.31 GiB size: 186.31 GiB (100.00%)
maj-min: 8:1
ID-4: /var/tmp raw-size: 186.31 GiB size: 186.31 GiB (100.00%)
maj-min: 8:1
System Temperatures: cpu: 33.0 C mobo: N/A gpu: radeon temp: 38.0 C
Processes: 215 Uptime: 2h 32m wakeups: 80 Memory: 15.54 GiB
used: 2.3 GiB (14.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1557
libs: 492 tools: gnome-software,octopi,pamac,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.10-1):
System install date: 2022-12-18
Last full system update: 2022-12-24
bluetooth connects to my phone but not to my Tech Inc bt speaker
any help appreciated
