Rahul
21 December 2020 17:36
#1
I am unable to fix Bluetooth headset connection,, always getting error code of protocol not available .... Kindly send me the command for it to fix it
Too maney time used
Sudo Pacman -S pulseaudio-bluetooth
But nothing happens.... Help me please
SGS
21 December 2020 17:53
#2
Do you search in Forum?
Sudo Pacman -S pulseaudio-bluetooth ??? or
sudo pacman -S pulseaudio-bluetooth
dr460nf1r3
Garuda Team
2d
If pulseaudio-modules-bt is installed, do the following to replace it:
Sorry am posting this when someone else already have posted this because i can't see any solution there .
Output of inxi -Fxxxza and systemctl status bluetooth . I have tried systemctl enable --now bluetooth too. Bluedevil package was already installed and reinstalling it didn't helped me tho. I am also on a system with Windows and Garuda dual booted.
If you get some time please try to fix it. (I don't use Bluetooth oftenly, just trying to contribute)
Overall your work is SO GREAT!!!
You guy…
and
