Bluetooth headphones not connecting
When attempting to connect Bluetooth devices, nothing shows up in the menu after waiting for 3+ minutes. The device, headphones, aren’t connected to any other device and are set to pairing. Help would be greatly appreciated!
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ed68ed75-9c84-4c13-ae36-44a89adb019b rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Mobo: ASUSTeK model: PRIME X670-P WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0823
date: 11/21/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 400 min/max: 400/5453 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 112585
Device-1: AMD Navi 33 [Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3 code: Navi-33
process: TSMC n6 (6nm) built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0
chip-ID: 1002:7480 class-ID: 0300
gpu: amdgpu display-ID: 0
drv: radeonsi inactive: gbm
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7600 (gfx1102 LLVM
16.0.6 DRM 3.54 6.6.2-zen1-1-zen) device-ID: 1002:7480 memory: 7.81 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 7600 (RADV GFX1102) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:7480 surfaces: xcb,xlib,wayland device: 1 type: cpu
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0a:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-2: Realtek vendor: AzureWave driver: rtw89_8852be v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0b:00.0
chip-ID: 10ec:b852 class-ID: 0280
IF: wlp11s0 state: down mac: <filter>
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 13d3:3571
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.85 TiB used: 110.93 GiB (5.9%)
fw-rev: 2B2QEXM7 temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: N/A size: 29.3 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 110.93 GiB (6.0%)
used: 110.93 GiB (6.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.09 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.8 C mobo: N/A gpu: amdgpu temp: 40.0 C
mem: 54.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1
Processes: 345 Uptime: 4m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.09 GiB used: 2.68 GiB (8.6%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1439 libs: 447 tools: octopi,pamac,paru
Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-05
Last full system update: 2023-11-27
It looks like the computer is not in pairing mode
Double-check the module is loaded.
modinfo btusb
Check for issues with the service:
systemctl status bluetooth.service
I’m not sure if KDE uses the systemd service or not but it can’t hurt to check for errors.
If the driver and the service are all good, the manual way to pair a device is here: https://wiki.archlinux.org/title/bluetooth#Pairing
I am sure there is some way to manage that from the GUI but I have not learned about that yet. Maybe you could add a screenshot so we can see what the method you are trying looks like.
Ok, now it’s showing up in the bluetooth menu, but when I attempt to pair to it, it tells me “The setup of WH-CH510 [the headphones] has failed” with no other information about what went wrong.
Bummer. How about that other stuff though?
other stuff looked fine, although I’m not exactly sure what to be looking for as I’m new to linux
modinfo btusb
filename:       /lib/modules/6.6.2-zen1-1-zen/kernel/drivers/bluetooth/btusb.ko.zst
license:        GPL
version:        0.8
description:    Generic Bluetooth USB driver ver 0.8
author:         Marcel Holtmann <[email protected]>
srcversion:     F694551F9E01F27FA9D7B6B
alias:          usb:v8087p0A5Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0930p*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v413Cp*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v13D3p*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v050Dp*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v0B05p*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v0A5Cp*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v04CAp*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v0489p*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v0BB4p*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v105Bp*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v19FFp0239d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0C10p0000d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDBp1002d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v044Ep3002d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v044Ep3001d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04BFp030Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v057Cp3800d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v05ACp8281d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v05ACp821Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v05ACp821Fd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v05ACp821Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v05ACp8218d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v05ACp8215d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v05ACp8213d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0A5Cp21E1d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E8Dp763Fd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v05ACp*d*dc*dsc*dp*icFFisc01ip01in*
alias:          usb:v*p*d*dc*dsc*dp*icE0isc01ip01in*
alias:          usb:v*p*d*dcE0dsc01dp04ic*isc*ip*in*
alias:          usb:v*p*d*dcE0dsc01dp01ic*isc*ip*in*
alias:          of:N*T*Cusb4ca,301aC*
alias:          of:N*T*Cusbcf3,e300C*
alias:          of:N*T*Cusb1286,204eC*
depends:        bluetooth,btmtk,btintel,btbcm,btrtl
retpoline:      Y
intree:         Y
vermagic:       6.6.2-zen1-1-zen SMP preempt mod_unload
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        33:AF:C3:91:5F:09:29:28:03:2F:F6:0F:76:B1:94:69:55:FF:95:F1
sig_hashalgo:   sha512
signature:      30:64:02:30:07:6A:22:BF:AF:FD:AA:36:22:C1:C7:8A:63:B7:12:D3:
9C:E6:9B:8A:D3:C0:75:18:F0:12:87:C3:C0:BB:A3:FA:87:E1:22:5B:
F5:E1:65:3F:0A:1A:1E:9E:2B:3C:C3:B0:02:30:41:08:32:B1:86:55:
79:2C:45:42:78:B7:5F:7B:AE:0C:D5:0E:C5:F1:CC:79:63:E2:AC:36:
2B:F6:0F:6C:4C:2F:C2:65:5B:2E:11:58:06:C9:44:05:9C:66:41:10:
0A:89
parm:           disable_scofix:Disable fixup of wrong SCO buffer size (bool)
parm:           force_scofix:Force fixup of wrong SCO buffers size (bool)
parm:           enable_autosuspend:Enable USB autosuspend by default (bool)
parm:           reset:Send HCI reset command on initialization (bool)
bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Tue 2023-11-28 17:39:14 EST; 2h 57min ago
Docs: man:bluetoothd(8)
Main PID: 744 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 37453)
Memory: 3.5M
CPU: 34ms
CGroup: /system.slice/bluetooth.service
└─744 /usr/lib/bluetooth/bluetoothd
Nov 28 19:55:07 the-Microwave bluetoothd[744]: Endpoint registered: sender=:1.51 path=/MediaEndpoint/A2DPSour>
Nov 28 19:55:07 the-Microwave bluetoothd[744]: Endpoint registered: sender=:1.51 path=/MediaEndpoint/A2DPSink>
Let’s try this:
Start bluetoothctl:
bluetoothctl
That will open a special bluetoothctl prompt where you can enter these commands:
discoverable on
pairable on
Then quit out of it.
quit
Then try pairing your device in the GUI settings menu from your screenshot.
The same error code appeared from the last screen shot. I’m thinking it might be a driver issue with my MoBo.
Try switching to the LTS kernel and see if you get a different result.
how do I do that?
Install the kernel and headers:
Then reboot. In the Grub menu, choose the advanced options and look for the LTS kernel.
This?
Yes, it looks like you have it installed. Go ahead and try booting with it.
Same error message
Just found this command line - Connect to a Bluetooth device via Terminal - Unix & Linux Stack Exchange, maybe that way at least will return some meaningful error message right away?
Hi @Popcorn , i think this is similar to that topic check it out
