I have a bluetooth keyboard and mouse and Garuda fails to connect to the bluetooth devices until after I've logged into the computer. Obviously this is a problem when the HID are all bluetooth. Right now I have to plug in a USB keyboard and mouse to get logged in every time I restart the computer.
Once logged it it will connect to them with no other prompting. The computer doesn't seem to have this issue waking from sleep, just from a cold boot. Do I need to update some drivers or something?
I appologize if these seem like really obvious questions or obvious solutions as I've never used linux outside of an appliance device before.
System: Kernel: 5.10.8-112-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=328298ae-2aaa-498b-b0f7-d8b429022ec8 rw rootflags=subvol=@ quiet splash
rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Desktop System: Gigabyte product: AB350M-D3H v: N/A serial: <filter>
Mobo: Gigabyte model: AB350M-D3H-CF v: x.x serial: <filter> UEFI: American Megatrends v: F2
date: 04/07/2017
Battery: Device-1: hid-dc:2c:26:e7:57:eb-battery model: Keychron K2 serial: N/A charge: N/A
status: Discharging
CPU: Info: Quad Core model: AMD Ryzen 5 1400 bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 1
stepping: 1 microcode: 800111C L2 cache: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 51156
Speed: 1483 MHz min/max: 1550/3200 MHz boost: disabled Core speeds (MHz): 1: 1483 2: 1466 3: 1516
4: 1502 5: 1440 6: 1454 7: 1471 8: 1408
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 09:00.0 chip ID: 1002:67df
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0") s-diag: 987mm (38.8")
Monitor-1: DisplayPort-2 res: 3440x1440 hz: 144 dpi: 109 size: 800x335mm (31.5x13.2")
diag: 867mm (34.1")
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.40.0 5.10.8-112-tkg-bmq LLVM 11.0.1)
v: 4.6 Mesa 20.3.3 direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 09:00.1 chip ID: 1002:aaf0
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 12:00.3 chip ID: 1022:1457
Device-3: Blue Microphones Yeti Stereo Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-3:2 chip ID: b58e:9e84 serial: <filter>
Device-4: Kingston HyperX Cloud Flight S type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-2:2 chip ID: 0951:16ea serial: <filter>
Sound Server: ALSA v: k5.10.8-112-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: f000 bus ID: 05:00.0 chip ID: 10ec:8168
Drives: Local Storage: total: 689.33 GiB used: 38.26 GiB (5.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST240HM000-1G5152 size: 223.57 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: C675
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 3B6Q
Partition: ID-1: / raw size: 232.57 GiB size: 232.57 GiB (100.00%) used: 38.24 GiB (16.4%) fs: btrfs
dev: /dev/sdb5 maj-min: 8:21
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%) used: 25.5 MiB (26.6%) fs: vfat
dev: /dev/sdb2 maj-min: 8:18
ID-3: /home raw size: 232.57 GiB size: 232.57 GiB (100.00%) used: 38.24 GiB (16.4%) fs: btrfs
ID-4: /var/log raw size: 232.57 GiB size: 232.57 GiB (100.00%) used: 38.24 GiB (16.4%) fs: btrfs
ID-5: /var/tmp raw size: 232.57 GiB size: 232.57 GiB (100.00%) used: 38.24 GiB (16.4%) fs: btrfs
ID-1: swap-1 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 59.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1124
Info: Processes: 340 Uptime: 2m wakeups: 1 Memory: 15.64 GiB used: 4.93 GiB (31.5%) Init: systemd v: 247
Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1628 lib: 523 flatpak: 0 Shell: fish
v: 3.1.2 running in: alacritty inxi: 3.2.01
