Bluetooth fail to pair previous connected devices on clean install
So i just clean install garuda and i have this weird things where i cannot pair previous devices that was pair on the same hardware beofre the clean install. It also fail if i tried to pair them on other live distro. I have read and tried multiple stuff that was present on the arch wiki without sucess.
The bluetooth does work, i can see them during scan and even connect to them but it will disconect shortly after cause they arent paired.
Devices that werent connected on that hardware pair and connect withot any error. I already tried to reset factory the headset but it didnt change anything to my issue
Kernel: 6.6.2-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=61948177-a3b3-4b12-941f-f5b21febe7f5 rw rootflags=subvol=@
quiet resume=UUID=8dfa610f-7554-4173-b2c6-1951b938f62c loglevel=3 ibt=off
Type: Laptop System: HUAWEI product: CREM-WXX9 v: M1010
Mobo: HUAWEI model: CREM-WXX9-PCB-B1 v: M1010 serial: <superuser required>
UEFI: HUAWEI v: 2.26 date: 05/13/2022
ID-1: BATT charge: 42.6 Wh (61.4%) condition: 69.4/83.1 Wh (83.5%)
volts: 12.1 min: 11.5 model: DYNAPACK HB9790T7ECW-32T0 type: Li-ion
serial: <filter> status: charging cycles: 251
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1440 high: 4338 min/max: 400/4463 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3428 2: 400 3: 400
4: 400 5: 400 6: 400 7: 4000 8: 3420 9: 400 10: 400 11: 400 12: 400
13: 400 14: 4338 15: 3459 16: 400 bogomips: 102248
vendor: Wingtech driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 63.0 C
Device-2: ShineTech HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 3277:0003
Screen-1: 0 s-res: 2520x1680 s-dpi: 96 s-size: 666x444mm (26.22x17.48")
s-diag: 800mm (31.51")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x092f serial: <filter>
built: 2021 res: 2520x1680 hz: 60 dpi: 189 gamma: 1.2
size: 338x226mm (13.31x8.9") diag: 407mm (16") ratio: 3:2 modes:
max: 2520x1680 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.6.2-AMD-znver3) device-ID: 1002:1638 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: AMD Renoir Radeon High Definition Audio vendor: Wingtech
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Wingtech
driver: N/A alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Wingtech
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.6.2-AMD-znver3 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
vendor: & Tele RSH driver: rtw_8822ce v: kernel modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 1358:c123
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 505.94 GiB used: 353.7 GiB (69.9%)
model: PC SN730 SDBPNTY-512G size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11120000 temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: USB Disk 3.0 size: 29 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 8.01 scheme: MBR
ID-1: / raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
used: 353.69 GiB (76.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-4: /var/log raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.48 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 95.0 C mobo: N/A gpu: amdgpu temp: 67.0 C
Fan Speeds (rpm): fan-1: 3232 fan-2: 3166
Processes: 361 Uptime: 15m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15 GiB used: 4.56 GiB (30.4%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1889 libs: 552 tools: octopi,pamac,paru
Shell: fish v: 3.6.1 running-in: yakuake inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-22
Last full system update: 2023-11-24
need to manually do that command to load bluetooth modula that isnt load by dracut
sudo modprobe btusb
