Hello Garuda users.
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_US.UTF-8",
LC_NAME = "en_US.UTF-8",
LC_MONETARY = "om_KE.UTF-8",
LC_PAPER = "en_US.UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8",
LC_TELEPHONE = "en_US.UTF-8",
LC_MEASUREMENT = "en_US.UTF-8",
LC_TIME = "en_US.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4c3e451d-5643-49a7-846d-10ef744f5132 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: HP product: HP EliteBook 840 G3 v: N/A
serial: Chassis: type: 10 serial:
Mobo: HP model: 8079 v: KBC Version 85.79 serial:
UEFI: HP v: N75 Ver. 01.57 date: 07/28/2022
ID-1: BAT0 charge: 8.7 Wh (23.6%) condition: 36.9/46.5 Wh (79.4%)
volts: 10.8 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: status: discharging cycles: 404
Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 500 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 22399
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
EliteBook 840 G3 driver: i915 v: kernel arch: Gen-9 process: Intel 14n
built: 2015-16 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Monitor-1: eDP-1 model: AU Optronics 0x123d built: 2013 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 520 (SKL
GT2) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard EliteBook
840 G3 driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard EliteBook 840 G3
driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f
IF: enp0s31f6 state: down mac:
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp1s0 state: up mac:
bus-ID: 1-7:3 chip-ID: 8087:0a2b class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 704.24 GiB used: 42.55 GiB (6.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500VT000-1BS142
type: HDD rpm: 5400 serial: rev: PTC1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Intel model: SSDSCKKF256G8H
type: SSD serial: rev: H03N scheme: GPT
used: 42.53 GiB (17.9%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 25.8 MiB (8.6%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 7.06 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C pch: 35.5 C mobo: N/A
Processes: 198 Uptime: 6m wakeups: 1 Memory: 7.06 GiB used: 3.27 GiB (46.4%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1388 libs: 353
tools: octopi,paru Shell: fish v: 3.5.1 running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-10-02
Last full system update: 2022-11-11
Windows dual boot: No
I recently updated my machine and I cant really get any sound coming out of my earbuds or generally Bluetooth audio devices its kind of hit and miss really sometimes it might work with choppy sound or sometimes it might go to the extend of powering off my bluetooth speakers/ earbuds.
From my research ive heard the problem is related to jamesdsp and pulse audio and so I uninstalled and installed it but to no avail. I also get that its possible that there might be interference with the Bluetooth speakers but I can assure you that there is no interference.
Anyone please help
