Bluetooth discovery issues
OK. Been running Dragonized Garuda on an older laptop for a couple months now, and I love it. Smooth, fast, the whole thing. The only “issue” I’m having is finding any BT device I want to connect to. Mouse, headphones, what have you. When I scan, I get a list of numbers and letters, but nothing to discern the device I want to connect to. I’ve tried process of elimination, and that’s just about impossible because the list is big (2 dozen maybe) and it’s constantly refreshing, So I can’t keep track of what I have already tried.
Any tips for how to either make it show the name or find my device?
Kernel: 6.12.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=7e8b23cc-1bfe-49d0-8364-b89765ff553d rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: G75VX v: 1.0
Mobo: ASUSTeK model: G75VX v: 1.0 serial: <superuser required>
part-nu: ASUS-NotebookSKU uuid: <superuser required>
UEFI: American Megatrends v: G75VX.206 date: 02/27/2013
ID-1: BAT0 charge: 62.7 Wh (96.3%) condition: 65.1/77.0 Wh (84.6%)
volts: 14.8 min: 14.8 model: ASUSTek G75--52 type: Li-ion serial: N/A
status: not charging cycles: 769
Info: model: Intel Core i7-3630QM bits: 64 type: MT MCP arch: Ivy Bridge
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3400 min/max: 1200/3400 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3400 2: 3400 3: 3400 4: 3400 5: 3400 6: 3400
7: 3400 8: 3400 bogomips: 38313
Device-1: NVIDIA GK104M [GeForce GTX 670MX] vendor: ASUSTeK driver: nouveau
v: kernel non-free: series: 470.xx+ status: legacy-active (EOL~2024-09-xx)
arch: Kepler-2 code: GKxxx process: TSMC 28nm built: 2012-2018 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 01:00.0
chip-ID: 10de:11a1 class-ID: 0300 temp: 49.0 C
Device-2: Sunplus Innovation ASUS Webcam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:4
chip-ID: 1bcf:2885 class-ID: 0e02
compositor: kwin_wayland driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: 0
Monitor-1: LVDS-1 model: AU Optronics 0x219d built: 2012 res:
mode: 1920x1080 hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 128 gamma: 1.2
size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9 modes:
max: 1920x1080 min: 640x350
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.3.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: NVE4 device-ID: 10de:11a1 memory: 2.92 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: N/A device-ID: 10005:0000
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
Device-2: NVIDIA GK104 HDMI Audio driver: snd_hda_intel v: kernel pcie:
bus-ID: 01:00.1 chip-ID: 10de:0e0a class-ID: 0403
API: ALSA v: k6.12.10-zen1-1-zen status: kernel-api with: aoss
Device-1: Broadcom BCM4352 802.11ac Dual Band Wireless Network Adapter
vendor: AzureWave driver: wl v: kernel modules: bcma pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:43b1 class-ID: 0280
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 04:00.0 chip-ID: 1969:1083 class-ID: 0200
Device-1: IMC Networks BCM20702A0 driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.1:3 chip-ID: 13d3:3404
Report: btmgmt ID: hci0 rfk-id: 31 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: yes class-ID: 6c010c
Local Storage: total: 2.73 TiB used: 364.97 GiB (13.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 2TB SSD
tech: SSD serial: <filter> fw-rev: 0600 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD4
tech: SSD serial: <filter> fw-rev: 023 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 114.63 GiB (6.2%)
used: 114.63 GiB (6.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 17.51 GiB used: 514 MiB (2.9%) priority: 100
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nouveau temp: 49.0 C
Fan Speeds (rpm): cpu: 2000
Memory: total: 20 GiB note: est. available: 17.51 GiB used: 7.27 GiB (41.5%)
Processes: 318 Power: uptime: 6d 17h 16m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 30 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.98 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1799 libs: 537 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date:     2024-12-19
Last full system update: 2025-01-26
Please post your garuda-inxi as requested by the template.
I don’t know if this is how it’s done, but I edited the post to reflect that output.
Almost perfect, please always use code blocks for terminal output. I fixed it :wink:
Thanks so much! I don’t even know what you said there. Like, what it means. I’ve been out of the forum game for a while.
hello,
maybe you can try another Kernel LTS to check if that problem happens to other Kernel or try X11 version because older bluetooth device.IMC Networks BCM20702A0 Bluetooth.
what is your output from bluetoothctl terminal? is there any error?
The only output was “Agent registered”
If it’s because my hardware is old, I get that. I may try a newer BT adapter and see if it changes discovery.
Yes because its not activated then you get the message "Agent registered.
You have a Broadcom device if im right.
Maybe you can check in Octopi to install the firmware driver for it.
Thanks for the help. Installed it, but nothing changed. Had an Asus BT dongle lying around. Popped that in and it showed names of what I was looking to pair with. Not too concerned with losing a USB port, still have 2 left.
Thanks again!
you can leave it for few days maybe someone have an idea or you set your answer as Solution :smiley:
I think I marked it solved. Your suggestion actually DID work, after I pulled the dongle and restarted the device names started showing up. So thanks a bunch!
my bluetooth looks like that activated :grin:
bluetoothctl
[bluetooth]# Agent registered
[bluetooth]# hci0 class of device changed: 0x000000
[bluetooth]# hci0 new_settings: bondable ssp br/edr le secure-conn wide-band-speech
[bluetooth]# [CHG] Controller 48:51:C5:F7:88:D3 Class: 0x00000000 (0)
[bluetooth]# [CHG] Controller 48:51:C5:F7:88:D3 Powered: no
[bluetooth]# [CHG] Controller 48:51:C5:F7:88:D3 Discovering: no
[bluetooth]# [CHG] Controller 48:51:C5:F7:88:D3 PowerState: on
[bluetooth]# [CHG] Controller 48:51:C5:F7:88:D3 PowerState: off-blocked
[bluetooth]# [CHG] Controller 48:51:C5:F7:88:D3 PowerState: off-enabling
[bluetooth]# hci0 class of device changed: 0x6c0104
[bluetooth]# [CHG] Controller 48:51:C5:F7:88:D3 Class: 0x006c0104 (7078148)
[bluetooth]# hci0 new_settings: powered bondable ssp br/edr le secure-conn wide-band-speech
[bluetooth]# [CHG] Controller 48:51:C5:F7:88:D3 Powered: yes
[bluetooth]#
if its off and i turn it on then it works for me with sony wi200 headset=)
