When i connect my bluetooth.. i m getting this status
systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2022-03-01 15:29:10 IST; 21min ago
Docs: man:bluetoothd(8)
Main PID: 554 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 3939)
Memory: 3.7M
CPU: 71ms
CGroup: /system.slice/bluetooth.service
└─554 /usr/lib/bluetooth/bluetoothd
Mar 01 15:30:10 ritesh-hp245g7notebookpc bluetoothd[554]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Mar 01 15:30:10 ritesh-hp245g7notebookpc bluetoothd[554]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/faststream
Mar 01 15:30:10 ritesh-hp245g7notebookpc bluetoothd[554]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/faststream_duplex
Mar 01 15:30:17 ritesh-hp245g7notebookpc bluetoothd[554]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Mar 01 15:30:22 ritesh-hp245g7notebookpc bluetoothd[554]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Mar 01 15:49:31 ritesh-hp245g7notebookpc bluetoothd[554]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to FC:58:FA:46:DD:90: Connection reset by peer (104)
Mar 01 15:49:31 ritesh-hp245g7notebookpc bluetoothd[554]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transpo>
Mar 01 15:49:37 ritesh-hp245g7notebookpc bluetoothd[554]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to FC:58:FA:46:DD:90: Host is down (112)
Mar 01 15:49:37 ritesh-hp245g7notebookpc bluetoothd[554]: src/device.c:search_cb() FC:58:FA:46:DD:90: error updating services: Host is down (112)
Mar 01 15:49:59 ritesh-hp245g7notebookpc bluetoothd[554]: /org/bluez/hci0/dev_FC_58_FA_46_DD_90/fd0: fd(41) ready
Was it like a temporary problem or e.g. solved with a reboot?
Otherwise, this is a forum for users, so it would be nice to document the solution for future readers.
I have undone the solution marker.
What are help seekers on the Internet supposed to think of us (Garuda Linux Forum) when they joyfully click on the link because it is marked as solved and then realize with disappointment that they have been fooled with this "solution".
I'll give the OP time to respond back with the garuda-inxi that was requested and a proper solution summation. Otherwise this thread is going to the dump because it is worthless as far helping other users and is only forum clutter as is.
