Lately when I put my computer to sleep and wake it up I have noticed the background changes to a solid blue color. This has happened twice in the last few days, both times where I put my computer to sleep and woke it back up. Restarting fixes the issue, but I would prefer an actual solution rather than a workaround.
I would like to point out that this issue cannot be replicated 100% of the time, the last two times it happened is when my computer was put to sleep overnight for long periods of time. I just did a test where I put my computer to sleep then immediately turned it back on and everything is fine.
I always update my system fully, and I have been using Garuda for almost 2 months without encountering this issue. This leads me to believe some recent update may have caused the problem?
System: Kernel: 5.13.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=8dd0cacc-65dc-4850-97f7-aa0ef9124754
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASRock model: AB350 Pro4 serial: <filter> UEFI: American Megatrends
v: P5.40 date: 12/19/2018
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 serial: <filter>
Device-2: sony_controller_battery_1c:a0:b8:dc:88:ed model: N/A serial: N/A charge: N/A
status: Charging
CPU: Info: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen family: 17 (23)
model-id: 1 stepping: 1 microcode: 8001137 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 76646
Speed: 2906 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz): 1: 2906 2: 2931
3: 2712 4: 2723 5: 3236 6: 2964 7: 2915 8: 2845 9: 2723 10: 2762 11: 3137 12: 3154
Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Micro-Star MSI
driver: amdgpu v: kernel bus-ID: 26:00.0 chip-ID: 1002:67df class-ID: 0300
Device-2: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-3:3
chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Display: wayland server: X.Org 1.21.1.2 compositor: gnome-shell driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.0x12.5") s-diag: 1064mm (41.9")
Monitor-1: XWAYLAND0 res: 1920x1200 hz: 60 dpi: 94 size: 520x320mm (20.5x12.6")
diag: 611mm (24")
Monitor-2: XWAYLAND2 res: 1920x1080 hz: 144 dpi: 94 size: 520x300mm (20.5x11.8")
diag: 600mm (23.6")
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.41.0 5.13.12-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 26:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Sony DualShock 4 [CUH-ZCT2x] type: USB driver: snd-usb-audio,sony,usbhid
bus-ID: 1-3:2 chip-ID: 054c:09cc class-ID: 0300
Device-4: Blue Microphones Yeti Stereo Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:2 chip-ID: b58e:9e84 class-ID: 0300
Device-5: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-3:3
Sound Server-1: ALSA v: k5.13.12-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169
v: kernel port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 2.5 TiB used: 298.17 GiB (11.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-00BN5A0 size: 931.51 GiB
serial: <filter> rev: 1A01 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST500LM000-1EJ162 size: 465.76 GiB
serial: <filter> rev: DEMG scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB model: External USB3.0 size: 698.64 GiB block-size:
physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 0204 scheme: GPT
Partition: ID-1: / raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 61.67 GiB (13.2%) fs: btrfs
dev: /dev/sdc2 maj-min: 8:34
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 61.67 GiB (13.2%) fs: btrfs
ID-4: /var/log raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 61.67 GiB (13.2%) fs: btrfs
ID-5: /var/tmp raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 61.67 GiB (13.2%) fs: btrfs
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 48.2 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1863
Info: Processes: 405 Uptime: 11h 47m wakeups: 23 Memory: 15.56 GiB used: 5.56 GiB (35.8%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1356
pacman: 1351 lib: 357 flatpak: 5 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: gnome-terminal inxi: 3.3.06
