Bitwarden-garuda?
╭─james@james in ~
╰─λ garuda-inxi
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=73c23039-fcbf-4985-9c10-a4426ad13bb9 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Micro-Star product: MS-7B79 v: 3.0
Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.G0
date: 07/27/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
Info: model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3134 high: 3205 min/max: 1550/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3000 2: 3199
3: 3199 4: 3196 5: 3202 6: 3000 7: 3183 8: 3200 9: 3199 10: 3197 11: 3200
12: 3205 13: 3000 14: 3000 15: 3168 16: 3000 bogomips: 95998
Device-1: NVIDIA GF108 [GeForce GT 630] vendor: ZOTAC driver: nouveau
v: kernel non-free: series: 390.xx+ status: legacy (EOL~2022-11-22) last:
release: 390.157 kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx
process: 40/28nm built: 2010-2016 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DVI-I-1,DVI-I-2 bus-ID: 27:00.0
chip-ID: 10de:0f00 class-ID: 0300 temp: 33.0 C
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: :0
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Samsung S24D590 serial: <filter>
built: 2014 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 23.3.5-arch1.1 glx-v: 1.4
direct-render: yes renderer: NVC1 device-ID: 10de:0f00 memory: 1.94 GiB
unified: no
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM 16.0.6)
Device-1: NVIDIA GF108 High Definition Audio vendor: ZOTAC
bus-ID: 27:00.1 chip-ID: 10de:0bea class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 29:00.3 chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
IF: enp34s0 state: down mac: <filter>
speed: 2.5 GT/s lanes: 1 bus-ID: 23:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp35s0 state: up mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:2 chip-ID: 8087:0a2a
Local Storage: total: 698.65 GiB used: 234.59 GiB (33.6%)
fw-rev: 2B2QEXM7 temp: 30.9 C scheme: GPT
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
scheme: MBR
used: 11.4 GiB (4.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.54 GiB used: 4 MiB (0.0%) priority: 100
System Temperatures: cpu: 34.0 C mobo: N/A gpu: nouveau temp: 33.0 C
Processes: 467 Uptime: 12m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 5.32 GiB (34.2%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1307
pm: pacman pkgs: 1299 libs: 365 tools: octopi,pamac,paru,yay pm: snap
pkgs: 8 Shell: fish v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.23-1):
System install date:     2024-02-01
Last full system update: 2024-02-07
HI,
thanks again for your help.
I wondered if bitwarden-garuda is the same than bitwarden ? If not, what is the advantage of garuda version?
also, if I use garuda version, can I use it on my android phoen too, kind of app?
thanks
https://bitwarden.garudalinux.org/#/login
Self hosted on Garuda Linux server.
Vaultwarden Web
Version 2024.1.2
A modified version of the Bitwarden® Web Vault for Vaultwarden (an unofficial rewrite of the Bitwarden® server).
Vaultwarden is not associated with the Bitwarden® project nor Bitwarden Inc.
I’m sorry but just like you should get Tor from their site and nowhere else get Bitwarden from there site and the extension / addon from the store for whichever browser you’re running,
Vaultwarden is open source software,
GitHub - dani-garcia/vaultwarden: Unofficial Bitwarden compatible server written in Rust, formerly known as bitwarden_rs,
like Bitwarden, available on Garuda Server.
You can of course also use the original
Bitwarden Password Manager Pricing | Bitwarden
but for us as a team it is cheaper self-hosted. :slight_smile:
Yes.
