While BTRFS snapper has worked for me in the past, it has also failed to "restore" the system twice, forcing me to re-install everything.
I want to have another form of backup. I came up with a possible solution and need some feedback. I wished to have back for both the bootloader (/boot/efi) and the root directory.
- Had an external HDD.
- Created a 300M partition and used
dd
to clone bootloader (/boot/efi). - Created a 458 GiB parition (same size as my root directory) and used
rsync
to create a backup of the system. Since my root partition is encrypted, I also encrypted my backup partition.
Is this setup sufficient?
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1d17e6de-9557-4600-a71d-2fc817db7784 rw rootflags=subvol=@
quiet
cryptdevice=UUID=ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d:luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d
root=/dev/mapper/luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d quiet splash
resume=/dev/mapper/luks-253338ee-7144-43f5-bc83-a762863e12f3 loglevel=3
mitigations=off
Type: Laptop System: ASUSTeK product: ROG Strix G713QM_G713QM v: 1.0
Mobo: ASUSTeK model: G713QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713QM.320 date: 06/30/2022
ID-1: BAT0 charge: 52.8 Wh (61.0%) condition: 86.5/90.0 Wh (96.1%)
volts: 15.8 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22 process: TSMC n7
(7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2869 high: 4246 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2013 2: 2152
3: 3104 4: 3200 5: 2897 6: 3200 7: 3200 8: 2350 9: 2139 10: 2112 11: 2511
12: 4246 13: 2996 14: 3200 15: 3398 16: 3200 bogomips: 102213
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none off: DP-1 empty: none
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 61.0 C
gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 93 s-size: 524x321mm (20.63x12.64")
s-diag: 615mm (24.19")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary
model: Acer B246WL serial: <filter> built: 2020 res: 1920x1200 hz: 60
dpi: 94 gamma: 1.2 size: 518x324mm (20.39x12.76") diag: 611mm (24.1")
ratio: 16:10 modes: max: 1920x1200 min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-0 note: disabled model: AU Optronics
0x8294 built: 2020 res: 1920x1200 dpi: 128 gamma: 1.2
size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2 v: 4.6.0
NVIDIA 515.76 direct render: Yes
driver: snd_hda_intel bus-ID: 3-2.2:9 v: kernel chip-ID: 0c76:1620 pcie:
class-ID: 0300 gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Device-5: JMTek LLC. USB PnP Audio Device type: USB
Sound API: ALSA v: k5.19.13-zen1-1-zen running: yes
bus-ID: 3-4:5 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 5.89 TiB used: 1.92 TiB (32.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX013N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41000C20
temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.13 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.14 GiB block-size: physical: 512 B
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital model: WD
My Passport 2627 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 4008 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Lenovo model: USB Hard
Drive size: 931.51 GiB block-size: physical: 512 B logical: 512 B
type: N/A serial: <filter> rev: 3U scheme: GPT
ID-1: / raw-size: 430.27 GiB size: 430.27 GiB (100.00%) used: 92.71 GiB
(21.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 752 KiB
ID-3: /home raw-size: 430.27 GiB size: 430.27 GiB (100.00%) used: 92.71
GiB (21.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 430.27 GiB size: 430.27 GiB (100.00%) used: 92.71
ID-5: /var/tmp raw-size: 430.27 GiB size: 430.27 GiB (100.00%) used: 92.71
ID-1: swap-1 type: zram size: 15.05 GiB used: 376.2 MiB (2.4%)
ID-2: swap-2 type: partition size: 16.56 GiB used: 0 KiB (0.0%)
mapped: luks-253338ee-7144-43f5-bc83-a762863e12f3
System Temperatures: cpu: 71.6 C mobo: N/A
Fan Speeds (RPM): cpu: 0
GPU: device: nvidia screen: :0.0 temp: 61 C device: amdgpu temp: 62.0 C
Processes: 497 Uptime: 1h 25m wakeups: 12 Memory: 15.05 GiB used: 4.71 GiB
(31.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2097
libs: 546 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-10-03
Last full system update: 2022-10-09
