Believe permission issue with a directory in Dolphin
As some know I installed a second copy of Garuda Dragonized Gaming to us Wayland and see what still needs work before the KDE devs drop Plasma 6.0. I got it all set up and yesterday I setup Emby. During the setup wizard I added all my libraries. All seemed good but for the TV Specials library. It will not show anything in Emby. Finally last night I thought to come back to my x11 version of Garuda and finish adding my libraries to Emby including TV Specials and got the exact same thing all libraries populating correctly in Emby except TV Specials. I have a thread on the Emby forums and so far we can’t seem to figure it out. At this point I’m thinking it must be changed permissions for that directory, but I’m not seeing anything unusual. Any suggestions and or thoughts on what might be happening would be greatly appreciated. Thanks
I’ve include the permissions list for what’s under Television and what under TV Specials. The only oddity is The Continental (2023) which is drwx------ instead of drwxr-xr-x.
https://emby.media/community/index.php?/topic/121901-tv-specials-not-populating/
░▒▓ ~  garuda-inxi
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c5a75bb7-e796-48c3-a70b-b3ec5203e7cb rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2806
date: 10/27/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3597 high: 3600 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3591 2: 3600
3: 3600 4: 3600 5: 3600 6: 3595 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600
12: 3588 bogomips: 86239
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Gigabyte
active: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 09:00.0
chip-ID: 1002:73ff class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-2 res: 2560x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (navi23 LLVM
16.0.6 DRM 3.54 6.5.5-zen1-1-zen) device-ID: 1002:73ff memory: 7.81 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.264 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 23.1.8-arch1.1
device-ID: 1002:73ff surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.1.8-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab28
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
Local Storage: total: 26.04 TiB used: 14.91 TiB (57.3%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 234100WD temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion HDD
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 0003 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000AS0002-1NA17Z
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5980
serial: <filter> scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: Expansion HDD
fw-rev: 1801 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: PNY model: USB 3.0 FD
size: 115.38 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: PMAP scheme: GPT
ID-1: / raw-size: 232.63 GiB size: 232.63 GiB (100.00%)
used: 20.15 GiB (8.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 211.8 MiB (41.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 232.63 GiB size: 232.63 GiB (100.00%)
ID-4: /var/log raw-size: 232.63 GiB size: 232.63 GiB (100.00%)
ID-5: /var/tmp raw-size: 232.63 GiB size: 232.63 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.35 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 35.0 C
mem: 34.0 C
Processes: 472 Uptime: 31m wakeups: 6 Memory: total: 24 GiB
available: 23.35 GiB used: 5.22 GiB (22.4%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 2139
pm: pacman pkgs: 2124 libs: 579 tools: octopi,pamac,paru,pikaur pm: flatpak
pkgs: 15 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.30
System install date:     2023-09-24
Last full system update: 2023-09-30 ↻
drwxr-xr-x    - locutus 29 Sep 16:25  Last Night's
drwxr-xr-x    - locutus 29 Sep 07:07  Shows To Catch Up On - Finish
drwxr-xr-x    - locutus 29 Sep 12:34  TV Series
drwxr-xr-x    - locutus 29 Sep 06:38  TV Specials
drwxr-xr-x   - locutus 30 Jul  2020  10.5 (2004)
drwxr-xr-x   - locutus 10 Jun 07:08  10.5 Apocalypse (2006)
drwxr-xr-x   - locutus 20 Sep  2020  A Christmas Carol (2019)
drwxr-xr-x   - locutus  7 Jan  2020  Aftershock Earthquake In New York (1999)
drwxr-xr-x   - locutus  8 Jul  2020  Ascension (2014)
drwxr-xr-x   - locutus  2 Aug  2020  Coma (2012)
drwxr-xr-x   - locutus 21 Dec  2022  Dynasty: The Reunion (1991)
drwxr-xr-x   - locutus 20 Sep  2020  Firestarter: Rekindled (2002)
drwxr-xr-x   - locutus 12 Jul  2022  Flowers In the Attic: The Origin (2022)
drwxr-xr-x   - locutus  7 Dec  2020  Halo 4: Forward Unto Dawn (2012)
drwxr-xr-x   - locutus 11 Sep  2021  Impact (2009)
drwxr-xr-x   - locutus 18 Jul 07:02  Lifetime's V.C. Andrews Castell Series
drwxr-xr-x   - locutus 30 Jul 06:51  Lifetime's V.C. Andrews Cutler Series
drwxr-xr-x   - locutus 18 Jul 07:08  Lifetime's V.C. Andrews Landry Series
drwxr-xr-x   - locutus 31 Jul  2020  Meteor - Path To Destruction (2009)
drwxr-xr-x   - locutus 14 Aug  2020  Ring Of Fire (2012)
drwxr-xr-x   - locutus  6 Mar  2022  Rose Red (2002)
drwxr-xr-x   - locutus 31 Oct  2020  Supervolcano (2005)
drwxr-xr-x   - locutus 31 Jul  2020  The Andromeda Strain (2008)
drwx------   - locutus 29 Sep 06:38  The Continental (2023)
drwxr-xr-x   - locutus 31 Jul  2020  The Langoliers (1995)
drwxr-xr-x   - locutus 28 Aug  2021  The Martian Chronicles (1980)
drwxr-xr-x   - locutus 30 Jul  2020  The Tommyknockers (1993)
drwxr-xr-x   - locutus 30 Oct  2021  The War Of The Worlds (2019)
drwxr-xr-x   - locutus 27 Nov  2021  V (1983)
drwxr-xr-x   - locutus 19 Aug  2021  War And Remembrance (1988)
drwxr-xr-x   - locutus 31 Jul  2020  XIII: The Conspiracy (2008)
Oops!
You do not have permission to view this topic.
Just change to be sure :slight_smile:
Last full system update: 2023-09-29 ↻
Restart, it’s KDE :smiley:
Sorry I forgot a lot of forums you can’t browse if not logged in. As for the restart I’ll do it cause I forgot to, but under the Wayland Garuda I tried a logoff and a reboot and no change. As for the Continental I don’t see that messing with the main permissions for the parent folder, but yes I’ll address it’s oddity and fix the permissions.
I made a PDF if you feel like reviewing it. Fixed The Continental by replacing the parent folder and dropping the season folder with it’s content into it. Replaced the garuda-inxi with the one from the Wayland system.
Looks like at this point it must of been The Continental causing the problem, cause after fixing it’s permissions and doing a reboot I have my Specials showing in the TV Specials library.
