Highly respected community,
I recently switched from Garuda Dragonized to Garuda Qtile flavor. Everything works fine so far, except battery indication, which is crucial to me as I'm mainly using laptop for work. I started investigating the issue and bumped into the commented config, related to battery in qtile config.py:
#albattery.BatteryIcon(
# padding=0,
# scale=0.7,
# y_poss=2,
# theme_path=home + "/.config/qtile/icons/battery_icons_horiz",
# update_interval = 5,
# foreground = colors[5],
# background = colors[9]
# widget.Battery(
# font="Noto Sans",
# update_interval = 10,
# fontsize = 12,
# background = colors[9],
but when I tried uncommenting mantioned lines, Qtile errored due to missing albattery python import.
Then I discovered that Qtile istallation uses cbatticon
by default to show battery charge and mentioned config is not required. The thing that confuses me most in this situation, icon is correctly shown when laptop has battery fully charged and plugged into power. In all other situations(not fully charged or discharging), place for battery icon is dedicated on Qtile panel, but icon itself is not visible.
Will be very grateful for any help
