Battery at 50% or completely charged?
So, I use a lot my Switch Pro Controller on Garuda. And today I noticed something strange:
How can it be "Fully charged" but at 50% at the same time?
What's even weirder: I left it plugged charging overnight, after playing yesterday night. Then now I thought: "what if I apply the universal solution (turn off/turn on, or in this case, disconnect/reconnect)"
And there it is, 100%.
But the weird part about this is: yesterday when I went to bed, I turned the computer off. Right before posting this, I garuda-update'd it and restarted the computer again.
Why did Garuda updated the status only after removing the cable and plugging it again , even through these shutdowns?
  Kernel: 6.3.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=468e3250-834f-4678-85b1-f50f268e557d rw rootflags=subvol=@
    resume=UUID=92d5bc58-440e-4eab-9f01-4fa35d34e02b loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
  Type: Laptop System: Dell product: G5 5590 v: N/A serial: <filter> Chassis:
    type: 10 serial: <filter>
  Mobo: Dell model: 0F3T2G v: A00 serial: <filter> UEFI: Dell v: 1.22.0
    date: 11/10/2022
  ID-1: BAT0 charge: 48.6 Wh (100.0%) condition: 48.6/60.0 Wh (81.0%)
    volts: 16.8 min: 15.2 model: SMP DELL JJPFK87 type: Li-poly serial: <filter>
    status: full
  Device-1: nintendo_switch_controller_battery_0003:057E:2009.0001
    model: N/A serial: N/A charge: N/A status: discharging
  Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64
    type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
    process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
    microcode: 0xF2
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1750 high: 2600 min/max: 800/4500 base/boost: 4000/4500
    scaling: driver: intel_pstate governor: powersave volts: 1.2 V
    ext-clock: 100 MHz cores: 1: 900 2: 2600 3: 2600 4: 901 5: 2600 6: 900
    7: 900 8: 900 9: 2600 10: 2600 11: 900 12: 2600 bogomips: 62399
    ports: active: DP-3 off: eDP-1 empty: DP-1, DP-2, DP-4, DP-5, HDMI-A-1,
    HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell
    driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1f11 class-ID: 0300
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 0c45:671f
    class-ID: 0e02
  Screen-1: 0 s-res: 2560x2160 s-dpi: 96 s-size: 675x570mm (26.57x22.44")
    s-diag: 883mm (34.78")
  Monitor-1: DP-3 mapped: DP-1-0 pos: primary model: LG (GoldStar) ULTRAWIDE
    serial: <filter> built: 2013 res: 2560x1080 hz: 60 dpi: 81 gamma: 1.2
    size: 798x334mm (31.42x13.15") diag: 628mm (24.7") modes: max: 2560x1080
    min: 720x400
  Monitor-2: eDP-1 note: disabled model: BOE Display 0x084a built: 2018
    res: 2560x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
  API: OpenGL v: 4.6 Mesa 23.1.2 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct-render: Yes
  Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10f9 class-ID: 0403
  Device-3: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.5:12 chip-ID: 0bda:4014
  API: ALSA v: k6.3.8-zen1-1-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.71 status: n/a (root, process) with:
  Device-1: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502
  IF: enp60s0 state: down mac: <filter>
    vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 3d:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 48.0 C
  IF: wlp61s0 state: down mac: <filter>
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1.2:3
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 0cf3:e007
  Local Storage: total: 1.14 TiB used: 729.67 GiB (62.4%)
    model: PC SN520 NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 20240012 temp: 53.9 C scheme: GPT
  SMART: yes health: PASSED on: 1y 110d 15h cycles: 1,614
    read-units: 115,644,582 [59.2 TB] written-units: 113,300,847 [58.0 TB]
    model: WD10SPZX-75Z10T3 family: Blue Mobile (SMR) size: 931.51 GiB
    block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 4514 temp: 39 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 329d 21h cycles: 1609
    read: 24.39 TiB written: 14.91 TiB Old-Age: g-sense error rate: 15945
  ID-1: / raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
    used: 180.91 GiB (81.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2
    used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
    maj-min: 259:2
  ID-4: /var/log raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
    maj-min: 259:2
  ID-5: /var/tmp raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
    maj-min: 259:2
  ID-1: swap-1 type: zram size: 15.43 GiB used: 11.8 MiB (0.1%)
  ID-2: swap-2 type: partition size: 16.98 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 71.0 C mobo: 61.0 C
  Fan Speeds (RPM): cpu: 2403 fan-1: 2335
  Processes: 373 Uptime: 1m wakeups: 6 Memory: available: 15.43 GiB
  used: 6.06 GiB (39.3%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 2033 libs: 542 tools: gnome-software,octopi,pamac,paru,yay
  Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: kitty
  inxi: 3.3.27
  System install date:     2023-04-01
  Last full system update: 2023-06-16
Ask Nintendo if they fully support Linux.
I do not find the
part.
:rofl: Language barrier :rofl:
I found that part weird on the inxi too!!! it just doesn't mention it!
About the language barrier: "Completamente carregada" = "Fully charged".
And sorry, I was editing and updating the questioning on the opening when you answered...
Well, I would suggest to wait till it is fixed. Or create a bug request at kde.
Actually, these battery of other device feature are mostly under development, and are relatively new in Linux (like in development since only 1-2 years). So you can report a bug for developer. It will be best option.
Or you can wait for a few months. It will be eventually reported by some other user and fixed by the developers.
Here is how to report a bug at KDE
https://community.kde.org/Get_Involved/Issue_Reporting
wow, really? that feature is that new? Well, that explains it. Thanks for sharing that, @Naman!
It was released in 2019 with KDE 5.15 .You can check KDE 5.15 release logs for more info.
It is 4 years, my guess was a bit vague. Time flies by so fast.
But yeah, it is not that much robust for Nintendo and other proprietary devices.
But it is not exactly issue at KDE widget most probably. Actually, it is just a widget of KDE, and it actually takes data from upower and bluez
But the real blame is obviously Nintendo itself.......
