Hello.
I have this issue where my microphone has this terrible audio problem. When I was doing a quick check of my mic in Discord, there is this background noise (like some kind of whirring sound) that rhythmically goes in and out on regular intervals. To check, I booted into Windows and the issue was not present. I tried a couple of simple things such as disconnecting and reconnecting my headset, rebooting my system, and trying the onboard mic. None of these seemed to fix the issue. I understand that I can use Noisetorch, but because of this background noise, it severely affects my sound quality and cuts me off a lot.
My "inxi -Faz":
System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=fb4778c3-878f-4280-8097-00f152c54bf0
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A serial: <superuser required>
Chassis: type: 10 serial: <superuser required>
Mobo: Dell model: 0MK77P v: A00 serial: <superuser required> UEFI: Dell v: 1.11.0
date: 12/04/2019
Battery: ID-1: BAT0 charge: 52.1 Wh (100.0%) condition: 52.1/74.0 Wh (70.4%) volts: 12.3 min: 11.1
model: Samsung SDI DELL 0GFJ675 type: Li-ion serial: <filter> status: Full
CPU: Info: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: EA cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19999
Speed: 3349 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3349 2: 3229 3: 3351 4: 3228
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0300
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-12:6
chip-ID: 1bcf:28c1 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting,nvidia
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169
v: kernel port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel bus-ID: 03:00.0 chip-ID: 8086:3165
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
chip-ID: 8087:0a2a class-ID: e001
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Drives: Local Storage: total: 2.05 TiB used: 289.47 GiB (13.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 SATA 256GB size: 238.47 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: L003
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000LX001-1RG174 size: 1.82 TiB
serial: <filter> rev: SDM1 scheme: GPT
Partition: ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%) used: 21.35 GiB (21.9%) fs: btrfs
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.7 MiB (26.8%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 97.66 GiB size: 97.66 GiB (100.00%) used: 21.35 GiB (21.9%) fs: btrfs
ID-4: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%) used: 21.35 GiB (21.9%) fs: btrfs
ID-5: /var/tmp raw-size: 97.66 GiB size: 97.66 GiB (100.00%) used: 21.35 GiB (21.9%) fs: btrfs
ID-1: swap-1 type: zram size: 15.49 GiB used: 1.8 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 54.0 C pch: 49.5 C mobo: 42.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Info: Processes: 224 Uptime: 20m wakeups: 1 Memory: 15.49 GiB used: 3.76 GiB (24.3%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1560 lib: 419
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
