My ax200 intel pcie card that i have in my laptop have disconnect issues randomly.
It just disconnects and reconnects fairly quickly, but its annoying when you download something or watching streams.
Any help?
Thanks for the amazing distro.
PS. Using KDE lite, fresh install of the latest build.
It has been some time since your initial post. Have you made any progress with this issue?
If not, I can help with any steps you are unsure about. There are numerous things you could try to help improve your connectivity. Testing alternate iwlwifi firmware is one option. Ensuring your bios is up to date is also a way of eliminating the bios as a factor.
If you need further assistance, be sure to let me know. If your issue has been resolved then please be so kind as to mark your thread as solved.
So, i was testing the options and some other things, thats why i didnt reply.
Seems like the problem isnt so much on the Garuda's part, but on the network, or how generally linux handle this.
Im in a dorm, which has multiple 2.4 and 5GHz APs, all with the same name. If i fixed the network on a single AP MAC address, the problem seems to dissapear.
So, i concluded that its the way that it "jumps" between different APs trying to choose the closest one or whatever.
My Windows partition dont have this problem, but maybe it has a lower Roaming Aggressiveness so it doesnt change APs this much? Dunno.
Is there a way to reduce the Roaming Aggressiveness so the wifi doesnt try to change APs so much, or even restrict it only to 5GHz?
The less drastic way might be to try using nm-connection-editor. I'm not using WiFi right now, (so I'm not positive), but I think nm-connection-editor lets you select auto, 2.4, or 5 Ghz.
This of course assumes you are using Network Manager. It's been a long time since I've used Connman, so I'm not familiar with whether it has the ability to do the same.
Hey guys, I don't mean to raise this thread from the dead (but I am...)
I have a similar problem, and I've noticed it on my windows side as well. Everything works alright, but in some heavy downloading instances, the NIC eventually seems to give out, and disconnects. I have to DC from the wireless network, and then reconnect for it to start again, but if anything downloads at high speeds for too long, the same thing happens.
I was able to download the latest intel driver from their site and update the driver on the windows side of my machine to solve this. I'm just not sure how to manually update NIC drivers in Garuda. Any guidance here? I'm hoping a manual install to the latest driver from the intel site will fix the issue.
Hi there, welcome!
I'm afraid I have to ask you to open a new topic for your issue, in the Networking Support category.
We currently implement a rule to automatically close threads 15 days after the last post, but this is not retroactive.
Continuing an old post is never a good thing, as you can't be fully sure that the issues are identical.
Specifically, in this case, neither the OP nor you have provided your specifications via inxi -Faz (which is foundamental, especially for networking issues).
I take this opportunity to remind you to consider the information you will find in the template of the new topic: inxi -Faz, report everything you have tried, and most importantly searched for.
Here in the forum you could search within the "Networking Support" category using the name of your current card or driver.
