Hello.
Here's my inxi-Faz
╭─[email protected] in ~ took 8s
╰─λ inxi -Faz
System: Kernel: 5.14.6-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d9544bd3-6c1e-446a-bd11-bffba72af3a9 rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: awesome 4.3-1148-g87e09f81a vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20Y7CTO1WW v: ThinkPad E14 Gen 3 serial: <filter> Chassis: type: 10
Mobo: LENOVO model: 20Y7CTO1WW serial: <filter> UEFI: LENOVO v: R1OET28W (1.07 ) date: 07/15/2021
Battery: ID-1: BAT0 charge: 46.2 Wh (79.5%) condition: 58.1/57.0 Wh (101.9%) volts: 12.4 min: 11.5 model: Sunwoda 5B11C732
type: Li-poly serial: <filter> status: Unknown cycles: 6
CPU: Info: 8-Core model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 68 (104) stepping: 1 microcode: 8608103 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 57490
Speed: 1397 MHz min/max: 1400/4370 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1398 5: 1395
6: 1396 7: 1396 8: 1397 9: 1396 10: 1397 11: 1397 12: 1397 13: 1397 14: 1396 15: 1397 16: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Lucienne vendor: Lenovo driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:164c class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3 chip-ID: 04f2:b725 class-ID: fe01
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-de959 driver: loaded: amdgpu,ati unloaded: modesetting
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2") s-diag: 1055mm (41.5")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 96 size: 510x287mm (20.1x11.3") diag: 585mm (23")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.6-zen1-1-zen LLVM 12.0.1) v: 4.6 Mesa 21.2.2 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 04:00.1
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.14.6-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek vendor: Lenovo driver: rtw89_pci v: N/A modules: rtw89pci port: 2000 bus-ID: 03:00.0
chip-ID: 10ec:8852 class-ID: 0280
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 3-4:2 chip-ID: 0bda:4852 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Drives: Local Storage: total: 476.94 GiB used: 171.26 GiB (35.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HBLU-00BL1 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 6L1QFXM7 temp: 31.9 C
Partition: ID-1: / raw-size: 80 GiB size: 80 GiB (100.00%) used: 15.91 GiB (19.9%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 27.5 MiB (28.6%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 196.42 GiB size: 196.42 GiB (100.00%) used: 17.45 GiB (8.9%) fs: btrfs dev: /dev/nvme0n1p6
maj-min: 259:6
ID-4: /var/log raw-size: 80 GiB size: 80 GiB (100.00%) used: 15.91 GiB (19.9%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-5: /var/tmp raw-size: 80 GiB size: 80 GiB (100.00%) used: 15.91 GiB (19.9%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-1: swap-1 type: zram size: 13.48 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 44.4 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): fan-1: 1800
Info: Processes: 354 Uptime: 55m wakeups: 1 Memory: 13.48 GiB used: 4.6 GiB (34.1%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1337 lib: 331 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
I am running Garuda Linux Dr4g0n1zed version, which is using KDE Plasma.
Just recently installed awesome
to try out tiling window managers.
Then I go to https://github.com/manilarome/the-glorious-dotfiles
, to borrow the setup he made.
Then, when I log in to awesome wm, I found there is no wifi. So, I ran these following commands:
╭─[email protected] in ~ took 340ms
╰─λ sudo wpa_supplicant -B -D nl80211 -i wlp3s0 -c /etc/wpa_supplicant/wpa_supplicant.conf
Successfully initialized wpa_supplicant
nl80211: kernel reports: Match already configured
Following by:
╭─[email protected] in ~ took 54ms
╰─λ sudo dhclient
And then, I've successfully connected to my wifi.
But, the wifi will be disconnected after a short period of time, approximately 5 minutes or so. I have to run sudo dhclient
again to connect the wifi.
I've tried these commands to fix this problem:
╰─λ sudo systemctl enable wpa_supplicant.service
[sudo] password for jing:
Created symlink /etc/systemd/system/dbus-fi.w1.wpa_supplicant1.service → /usr/lib/systemd/system/wpa_supplicant.service.
Created symlink /etc/systemd/system/multi-user.target.wants/wpa_supplicant.service → /usr/lib/systemd/system/wpa_supplicant.service.
╭─[email protected] in ~ took 50ms
╰─λ sudo systemctl enable [email protected]
Created symlink /etc/systemd/system/multi-user.target.wants/[email protected] → /usr/lib/systemd/system/[email protected]
And then followed up with a reboot. But they didn't work, I still have to run wpa_supplicant
and dhclient
again and again.
I hope that someone can give me some help, any is appreciated.
I will keep adding more and more problems I've encountered here, hope that anyone else who is using awesomewm can also get some help.
EDIT 1:
I've encountered another problem about rofi
. As state in the screenshots of the github repo, it should be in full screen, with a search bar. But what I got is a half-screen menu with broken icon. After some debugging, I'm sure this is caused by rofi itself, but I don't know how to fix this issue.
