AVmatrix capture card driver installation missing dkms tool
Attempting to install the drivers for my AVmatrix capture card following the instructions posted here. GitHub - GloriousEggroll/AVMATRIX-VC12-4K-CAPTURE: Linux driver module for the AVMATRIX VC12-4k PCI-E capture card
when I attempt to run the command in the konsole to install the driver I get an error.
HWS Linux Driver Installer
Checking for required tools ...
Your system has one or more system tools missing which are
required to compile and load the HWS Linux driver.
Required tools:  dkms
Please check hws_install.log for more details.
If you are experiencing difficulty with this installation
I have attempted searching for how to add the DKMS tool, but all I’ve managed to find is instructions for how to use it, not add it if it missing. So I’m assuming it’s built in already or I’m using the wrong command. Any information would be appreciated for how to get this driver working. Apologies if the format of this post is incorrect, still learning and will correct it.
Kernel: 6.14.4-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=76e57c58-1384-40fa-ab5e-af49ca1a8952 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: X570 I AORUS PRO WIFI v: -CF
Mobo: Gigabyte model: X570 I AORUS PRO WIFI v: x.x
UEFI: American Megatrends v: F20 date: 07/07/2020
Info: model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/3700 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 59086
Device-1: Silicon Magic driver: N/A pcie: gen: 2 speed: 5 GT/s lanes: 4
bus-ID: 01:00.0 chip-ID: 8888:8581 class-ID: 0400
Device-2: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Gigabyte driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-2 empty: DP-1,HDMI-A-1
bus-ID: 09:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 43.0 C
Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:2
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Monitor-1: HDMI-A-2 model: D32f-F1 serial: <filter> built: 2016 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 70 gamma: 1.2
size: 698x392mm (27.48x15.43") diag: 801mm (31.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 11 Graphics
(radeonsi raven ACO DRM 3.61 6.14.4-zen1-2-zen) device-ID: 1002:15d8
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon Vega 11 Graphics (RADV RAVEN) driver: mesa radv v: 25.0.5-arch1.1
device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe
v: 25.0.5-arch1.1 (LLVM 19.1.7) device-ID: 10005:0000
Device-2: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.1 chip-ID: 1002:15de class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 09:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: HP HyperX Virtual Surround Sound
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 03f0:0b92 class-ID: 0300
Device-5: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.14.4-zen1-2-zen status: kernel-api tools: N/A
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 8087:0029
Local Storage: total: 1.14 TiB used: 15.93 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: USB 3.2Gen1
size: 232.97 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
used: 15.93 GiB (1.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 13.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.9 C mobo: 38.0 C gpu: amdgpu temp: 42.0 C
Memory: total: 16 GiB note: est. available: 13.59 GiB used: 4.29 GiB (31.6%)
Processes: 328 Power: uptime: 21h 31m states: freeze,mem,disk
reboot, suspend, test_resume image: 5.42 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1242 libs: 359 tools: octopi,paru Compilers:
inxi: 3.3.38
System install date:     2025-04-05
Last full system update: 2025-05-07 ↻
I suspect that this is a dkms driver. DKMS is not preinstalled on Garuda Linux, you can install it with:
sudo pacman -S dkms
then reboot and try to install the driver again.
Thank you that resolved it!
