Avatar by SGS
It was /usr/share/icons/hicolor/scalable/apps/ before.
For other links from you, I post 24/11/07 this :wink:
Thats right. Yeah I would just add the path to the one you made in the .desktop file its how I have to deal with apps like zed and nheko since it overwrites w/e upstream does. you can also just right click in the app launcher then use the edit mode to change them but I find this doesn’t work well for zed so I do it manually.
But I feel proton will fix the path in a later update i remember them doing stuff like this in the past.
I keep noticing that I think too complicatedly :smiley:
It works well. Thank you :slight_smile:
I miss the old way where you could get the “Properties” of just one app, Even asked kde but nope it’s no more.
My way :blush:
~/.config/inkscape/palettes/
Download
Paste the files in
╭─sgs@y7p in ~/.config/inkscape as 🧙 took 0s
🕙 08:39:24
╰─λ ls palettes/
.rw-r--r-- 531 sgs 21 Sep  2024  'Catppuccin Frappe.gpl'
.rw-r--r-- 530 sgs 21 Sep  2024  'Catppuccin Latte.gpl'
.rw-r--r-- 534 sgs 21 Sep  2024  'Catppuccin Macchiato.gpl'
.rw-r--r-- 530 sgs 21 Sep  2024  'Catppuccin Mocha.gpl'
Change the palette in inkscape.
Do you have one for sweet I had to manually make mine from getting the color values from the plasma color file. I’m fine with doing it that way but I know others might not be so keen.
Sorry, no. :slight_smile:
Little butterfly? :smiley:
11 posts were merged into an existing topic: Off Topic Chit Chat - (Silliness factor 5)
Friday the 13th
:black_cat:
:joy:
