Aux headphones not showing in port or autoconnecting
Hello Garuda users.
Im facing a problem with my aux headphones, first of all they dont autoconnect and my pc shows that nothing is plugged in the headphone port even though it is.
To use my headphones i have to go to settings->audio and change port to headphones(unplugged) and switch to pro audio, ive been doing this for a while but now its just frustrating
I have tried downloading alsa mixer and unmuting master but that did not help as well.
I couldnt find any other post related to this.
Any help would be appreciated.
My Laptop specs:
i5 10210u
8gb DDR4
uhd620 Graphics
Everything seemed to work fine on windows, also after switching to linux sometimes my headphones start giving me weird sound output like 8bit sound with a lot of
interruption which is not pleasant to the ears
TL;DR: my aux headphone dont autoconnect or show plz help
Kernel: 6.4.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=63b038a4-f596-466f-9617-1dafb23c18fb rw rootflags=subvol=@
Type: Laptop System: AVITA product: NS14A8 v: N/A
Mobo: AVITA model: 038-6H14CFWC86 v: V3.0 serial: <superuser required>
UEFI: American Megatrends v: BSR6IPHK-6H14C86-AVI-V31 date: 08/21/2020
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xF8
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1600 high: 1601 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1600 2: 1600 3: 1600
4: 1601 5: 1600 6: 1600 7: 1600 8: 1600 bogomips: 25599
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Alco Digital Devices
Device-2: Alcor Micro 720P USB Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4
chip-ID: 003f:00c1 class-ID: 0102
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1404 built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Realtek
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.4.10-zen2-1-zen status: kernel-api with: aoss
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: IMC Networks driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:5 chip-ID: 13d3:3503
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.1
lmp-v: 7 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 245.8 GiB used: 132.55 GiB (53.9%)
ID-1: /dev/mmcblk1 maj-min: 179:0 model: SD size: 7.32 GiB block-size:
physical: 512 B logical: 512 B type: USB tech: SSD serial: <filter>
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Foresee model: 256GB SSD
tech: SSD serial: <filter> fw-rev: 117H scheme: GPT
used: 132.55 GiB (55.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.64 GiB used: 1.79 GiB (23.5%)
System Temperatures: cpu: 54.0 C pch: 51.0 C mobo: N/A
Processes: 285 Uptime: 8m wakeups: 1 Memory: total: 8 GiB
available: 7.64 GiB used: 2.26 GiB (29.7%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 2068 pm: pacman pkgs: 2052 libs: 550 tools: octopi,paru
pm: flatpak pkgs: 16 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.29
System install date:     2023-08-15
Last full system update: 2023-08-25
Is partially upgraded:   Yes
