Hello everyone.
After a couple of decades of using windows, I found that Ms has more than crossed the line I feel comfortable with. I have been trying different distros for the last month and, to date, Garuda is the one I like the most. However, there are a couple of problems I haven't been able to fix myself nor find a solution online, so I am asking for help.
I use two drives: I one I keep the O.S., aps and games. The other holds my data I need to keep between installs and or in case of OS failure. I'd like to mount its folders as my user folders (Documents, downloads, videos, music...) as I had on Windows and KDE allows it. However the setting is lost between restarts as the drive must be manually mounted. To fix this, I modified "fstab" so the disk is automatically mounted during start up, witch indeed allowed me to keep my wished folder structure.
However that brought a VERY annoying problem: when I used to mount the drive manually, it had its own .Trash folder where deleted files were moved as expected. Now, deleted files are instead copied to my main drive which take a lot of time (I work often with videos of around 100 Gb) and will devastate its lifespan as it is an SSD.
I tryed mounting the drive in fstab with the lines:
"UUID="4CAA6027AA600FAE" /home/antonio/Datos ntfs defaults 0 0"
and
UUID="4CAA6027AA600FAE" /run/media/antonio/WD10SPZX040SATA ntfs user
(this last one I write from memory so may not be 100% correct).
Both gibe me the same result (different mounting folders) the drive gets auto-mounted, my custom personal folders work, but the trashed files from the secondary drive are copied to the trash bin on the primary.
I even reinstalled clean today to no avail.
I beg for some help.
Kernel: 5.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=810cddd0-3d54-45f7-88fa-84f8b12b1038 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-I GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4602
date: 08/17/2021
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4099 high: 4100 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4100 2: 4100
3: 4100 4: 4100 5: 4100 6: 4099 7: 4100 8: 4099 9: 4100 10: 4100 11: 4100
12: 4100 13: 4099 14: 4100 15: 4099 16: 4099 bogomips: 115198
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA 1
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 09:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1:2 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
s-diag: 1245mm (49.01")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-right
model: MSI MAG274QRF-QD serial: <filter> built: 2021 res: 2560x1440
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
Monitor-2: DP-3 mapped: DisplayPort-2 pos: bottom-l model: AOC 2590G4
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 90 gamma: 1.2
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
OpenGL:
renderer: AMD Radeon RX 5700 (navi10 LLVM 13.0.1 DRM 3.46 5.18.6-zen1-1-zen)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 1-1:2 pcie: chip-ID: 046d:0825 gen: 4 speed: 16 GT/s class-ID: 0102
lanes: 16 serial: <filter> bus-ID: 09:00.1 chip-ID: 1002:ab38
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Device-4: Logitech G432 Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3 chip-ID: 046d:0a9c
Sound Server-1: ALSA v: k5.18.6-zen1-1-zen running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 05:00.0 chip-ID: 10ec:b822
Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-8:5 chip-ID: 0b05:185c class-ID: e001 serial: <filter>
Local Storage: total: 1.84 TiB used: 902.26 GiB (47.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S0118C
temp: 35.9 C scheme: GPT
model: WD10SPZX-00Z10T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
used: 101.86 GiB (10.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.54 GiB used: 1.85 GiB (11.9%)
System Temperatures: cpu: 45.0 C mobo: 56.0 C gpu: amdgpu temp: 50.0 C
mem: 58.0 C
Fan Speeds (RPM): cpu: 680 case-1: 707 gpu: amdgpu fan: 862
Power: 12v: 9.97 5v: N/A 3.3v: N/A vbat: 3.23 gpu: amdgpu watts: 39.00
Processes: 381 Uptime: 3h 19m wakeups: 0 Memory: 15.54 GiB
used: 6.24 GiB (40.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1886
lib: 547 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-06-25
Last full system update: 2022-06-25
