Auto-cpufreq --install not working
I have tried to run auto-cpufreq to improve my battery life, my cpu min frequency is 1400,
output:
sudo auto-cpufreq --install
--------------------- Deploying auto-cpufreq as a daemon ----------------------
* Turn off bluetooth on boot
* Deploy auto-cpufreq install script
File "/usr/bin/auto-cpufreq", line 256, in <module>
main()
File "/usr/lib/python3.11/site-packages/click/core.py", line 1157, in __call__
return self.main(*args, **kwargs)
File "/usr/lib/python3.11/site-packages/click/core.py", line 1078, in main
rv = self.invoke(ctx)
File "/usr/lib/python3.11/site-packages/click/core.py", line 1434, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/lib/python3.11/site-packages/click/core.py", line 783, in invoke
return __callback(*args, **kwargs)
File "/usr/bin/auto-cpufreq", line 206, in main
deploy_daemon()
File "/usr/lib/python3.11/site-packages/auto_cpufreq/core.py", line 411, in deploy_daemon
shutil.copy(SCRIPTS_DIR / "auto-cpufreq-install.sh", "/usr/bin/auto-cpufreq-install")
File "/usr/lib/python3.11/shutil.py", line 419, in copy
copyfile(src, dst, follow_symlinks=follow_symlinks)
File "/usr/lib/python3.11/shutil.py", line 256, in copyfile
with open(src, 'rb') as fsrc:
FileNotFoundError: [Errno 2] No such file or directory: '/usr/share/auto-cpufreq/scripts/auto-cpufreq-install.sh'
Please post output of your garuda inxi like this from the terminal :
And please tell what are the steps that you took till now to resolve it and also how did you installed auto-cpufreq.
And welcome to garuda community forum :wink:
You can’t use that install script here it’s for debian, just turn on it’s systemd unit files
systemctl enable --now auto-cpufreq.service
Please read it’s readme it’s documented in the AUR section
You can (not mandatory) make /etc/auto-cpufreq.conf and copy paste the default settings from the github’s readme and edit it as needed. For example I have turned off my turbo boost since that was causing my cpu to stay needlessly hot while giving worse performance than without it. So I disabled it.
If you make changes to this file you need to reload the systemd service file for auto-cpufreq for it to read the changes.
Also do consider installing thermald alongside this and enable it’s systemd unit files as well.
Who knows, maybe he uses Debian?
Could be recognized by the garuda-inxi if he followed the template.
Kernel: 6.1.55-x64v1-xanmod1-1-lts arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc available: hpet,acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-lts
root=UUID=2c8ab2d6######-98d1-81e0b53c1d60 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X509DA_M509DA
Mobo: ASUSTeK model: X509DA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X509DA.306 date: 10/11/2019
ID-1: BAT0 charge: 23.7 Wh (100.0%) condition: 23.7/32.1 Wh (74.0%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 975
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1795 high: 2100 min/max: 1400/2100 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1389 2: 2100
3: 2100 4: 2100 5: 1232 6: 2100 7: 1243 8: 2100 bogomips: 33535
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 59.0 C
Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.2:5
chip-ID: 13d3:5a11 class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x07f1 built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon Vega 8
Graphics (raven LLVM 16.0.6 DRM 3.49 6.1.55-x64v1-xanmod1-1-lts)
direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5
API: ALSA v: k6.1.55-x64v1-xanmod1-1-lts status: kernel-api with: aoss
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.1:4
chip-ID: 8087:0a2b class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.2
Local Storage: total: 1.38 TiB used: 58.59 GiB (4.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 31.9 C scheme: GPT
model: WD10JPVX-60JC3T1 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
ID-1: / raw-size: 235.16 GiB size: 235.16 GiB (100.00%)
used: 58.56 GiB (24.9%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 32.7 MiB (12.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 235.16 GiB size: 235.16 GiB (100.00%)
ID-4: /var/log raw-size: 235.16 GiB size: 235.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 235.16 GiB size: 235.16 GiB (100.00%)
zswap: no
ID-1: swap-1 type: zram size: 9.66 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 1.95 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 60.1 C mobo: N/A gpu: amdgpu temp: 60.0 C
Fan Speeds (rpm): cpu: 2500
Processes: 277 Uptime: 11m wakeups: 1 Memory: total: 12 GiB note: est.
available: 9.66 GiB used: 3.08 GiB (31.9%) Init: systemd v: 254
pm: pacman pkgs: 2096 libs: 558 tools: octopi,pamac,paru,yay Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-08-06
Last full system update: 2023-09-26
Is partially upgraded:   Yes
I have tried it, it works but whenever I want to change performance to powersaving, it says to run --install command
That’s what the config file is for. By default the governer is powersaving while on battery and performance while charging. Create the /etc/auto-cpufreq.conf and change this behaviour as needed and reload the systemd unit to apply changes.
An example config on the project readme GitHub - AdnanHodzic/auto-cpufreq: Automatic CPU speed & power optimizer for Linux
