Hello Garuda world,
I installed Garuda Sway these days and had the issue after installation and reboot: I failed at login screen with Authentification error
My password was like x_xxxxxxxxx! with x = upper and lowercase letters.
first thought: I typed it wrong during install (but it is the same password I used for a long time and you have to type it two times)
I did a complete new install again and typed my password very "concentrated" during installation -> same result can't login
second thought: problem with keyboard language? Unfortunately there is no "eye" button to check what I typed in.
Installation #3: password = "a" (very simple, same position on US / Germany keyboard -> it works!
Now at least I can play around with Garuda Sway.
I added a test user -> password = x_xxxxxxxxx! -> su test and the password works -> logout and tryied to login with user test and password x_xxxxxxxxx! : same result Authentication error.
I tried "q" -> works
I tried "z" -> works with su test in terminal but not at login screen
Hi there, welcome!
I'm not a sway user, this is just an idea from some reading on the internet...
I think this means that your keymap after login (which is ok, if I understand correctly) is not the one used at login.
The former should be here
~/.config/sway/config
The latter maybe could be here
/etc/sway/inputs/default-keyboard
and maybe could be adjusted to be aligned with the former.
UPDATE:
I tried SDDM and LightDM with the same result.
At SDDM there is a language "selector" at the top left side.
US is already selected and in the drop down menu is US the only item.
It seams my language selection is after the login screen.
