Hy
I've been using garuda Linux (gnome edition) for quite some time, but I am facing some audio issues, Whenever I plug in headphones to my front audio out port, headphones work but the line-out port doesn't work, device is detected but no audio comes through, but as soon as I remove the front port device, lineout-port seems to work fine
garuda-inxi output
Kernel: 6.1.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8a6c9441-c6de-4fb3-8c0e-131b71406d50 rw [email protected]
loglevel=3 ibt=off
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop Mobo: Gigabyte model: B365M GAMING HD v: x.x
serial: <superuser required> UEFI: American Megatrends v: F3
date: 09/05/2019
Info: model: Intel Core i5-9600K bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF4
desc: 1x9 MiB
Speed (MHz): avg: 4400 high: 4403 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 4401 2: 4401 3: 4402
4: 4396 5: 4403 6: 4401 bogomips: 44398
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: Shenzhen Colorful Yugong
and Development driver: nvidia v: 525.78.01 alternate: nouveau,nvidia_drm
non-free: 525.xx+ status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:2184 class-ID: 0300
compositor: gnome-shell driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3640x1920 s-dpi: 96 s-size: 963x508mm (37.91x20.00")
s-diag: 1089mm (42.87")
Monitor-1: DP-0 pos: primary,bottom-l res: 2560x1440 hz: 144 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: HDMI-0 pos: top-right res: 1080x1920 dpi: 91
size: 300x530mm (11.81x20.87") diag: 609mm (23.98") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.78.01 renderer: NVIDIA GeForce GTX
1660/PCIe/SSE2 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA TU116 High Definition Audio vendor: Shenzhen Colorful
Yugong and Development driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
Sound API: ALSA v: k6.1.3-zen1-1-zen running: yes
lanes: 1 port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: TP-Link 802.11ac WLAN Adapter type: USB driver: rtl8821au
bus-ID: 1-6:3 chip-ID: 2357:011f class-ID: 0000 serial: <filter>
IF: wlp0s20f0u6 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-5:2 chip-ID: 0a12:0001 class-ID: e001
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 1.14 TiB used: 333.71 GiB (28.7%)
model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
rev: 211070WD temp: 37.9 C scheme: GPT
model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
used: 68.65 GiB (29.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.45 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.0 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 44%
Processes: 315 Uptime: 32m wakeups: 0 Memory: 15.45 GiB
used: 5.42 GiB (35.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 11 Packages: pm: pacman
pkgs: 1315 libs: 397 tools: pamac,paru Shell: fish v: 3.5.1
running-in: gnome-terminal inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-11-15
Last full system update: 2023-01-08 ↻
