Kernel: 5.16.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8036683d-e3aa-4e06-91b3-3774cebc7a89 rw rootflags=subvol=@
resume=UUID=5f72f88b-747a-42ab-a2c6-06e4be723fb7 loglevel=3 quiet
Type: Laptop System: Micro-Star product: GP75 Leopard 9SD v: REV:1.0
Mobo: Micro-Star model: MS-17E2 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E17E2IMS.10E date: 03/28/2019
ID-1: BAT1 charge: 38.5 Wh (96.0%) condition: 40.1/51.6 Wh (77.8%)
volts: 12.0 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: Charging
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2191
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 128
size: 381x214mm (15.0x8.4") diag: 437mm (17.2")
v: 4.6 Mesa 21.3.4 direct render: Yes
Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
Sound Server-1: ALSA v: k5.16.1-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: 3000 bus-ID: 05:00.0
chip-ID: 1969:e0a1 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 1.61 TiB used: 25.51 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
rev: ECFM22.5 temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Kingston
model: RBUSNS8154P3256GJ size: 238.47 GiB block-size: physical: 512 B
rev: E8FK11.C temp: 34.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: SDM1
ID-1: / raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
used: 25.51 GiB (5.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-4: /var/log raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.96 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.0 C pch: 47.0 C mobo: N/A
Processes: 333 Uptime: 54m wakeups: 1 Memory: 15.42 GiB
used: 4.21 GiB (27.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2382 lib: 539 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
Please use three ~ in first and last line from terminal output.
Hi, when i tried to remove totally pulseaudio to import and install pipewire, i tried to remove some pulseaudio library, and i think that after that i can't found any audio settings on my pc, what package or library i have to reinstall?
