I have had this issue for 4 months now and I would appreciate any assistance. Thanks
Kernel: 6.1.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f6e631a5-e2d8-413f-a8f4-bbbf2118d400 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: Dell product: Latitude E5550 v: N/A
serial: Chassis: type: 9 serial:
Mobo: Dell model: 0TR3VC v: A00 serial: UEFI: Dell
v: A13 date: 06/23/2016
ID-1: BAT0 charge: 19.2 Wh (73.6%) condition: 26.1/38.8 Wh (67.3%)
volts: 12.6 min: 11.4 model: Samsung SDI DELL R5MD0D9 type: Li-poly
serial: status: charging
Info: model: Intel Core i7-5600U bits: 64 type: MT MCP arch: Broadwell
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2478 high: 3082 min/max: 500/3200 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1673 2: 2616 3: 2541
4: 3082 bogomips: 20750
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-1.6:4 chip-ID: 0c45:6709 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.7
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c5 built: 2014 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
Sound API: ALSA v: k6.1.9-zen1-2-zen running: yes
Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
IF: eno1 state: down mac:
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp2s0 state: up mac:
Device-3: ZTE WCDMA MSM DEMO Mobile Boardband type: USB
driver: cdc_ether,usb-storage bus-ID: 2-2:14 chip-ID: 19d2:1405
class-ID: 0806 serial:
IF: enp0s20u2 state: up speed: 150 Mbps duplex: half mac:
IF-ID-1: br-7eaf0cfb76fd state: down mac:
IF-ID-2: br-e475deef7b8c state: down mac:
IF-ID-3: br-f508830f980c state: down mac:
IF-ID-4: br-fcb110c88bd4 state: down mac:
IF-ID-5: docker0 state: down mac:
bus-ID: 1-1.3:3 chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 476.94 GiB used: 92.6 GiB (19.4%)
ID-1: /dev/sda maj-min: 8:0 model: SSD 512GB size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial:
rev: 026D scheme: GPT
ID-1: / raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
used: 92.57 GiB (39.5%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 27.6 MiB (28.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
ID-4: /var/log raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
ID-5: /var/tmp raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.57 GiB used: 2.32 GiB (20.1%)
System Temperatures: cpu: 86.0 C mobo: 57.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 3706
Processes: 266 Uptime: 2h 19m wakeups: 2 Memory: 11.57 GiB
used: 6.85 GiB (59.2%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1965
libs: 532 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2022-09-16
Last full system update: 2023-02-19
Is partially upgraded: Yes
Failed units: systemd-backlight@leds:dell::kbd_backlight.service systemd-vconsole-setup.service
