Audio not working for about 4 months now
I am having the same issue with my audio not working for about 4 months now.
I tried the last 3 commands and this is what i got
 systemctl status --user pipewire
× pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
Active: failed (Result: exit-code) since Fri 2023-05-12 23:19:42 WAT; 8min ago
Duration: 29ms
TriggeredBy: × pipewire.socket
Process: 12100 ExecStart=/usr/bin/pipewire (code=exited, status=254)
Main PID: 12100 (code=exited, status=254)
CPU: 25ms
May 12 23:19:42 admin-latitudee5550 systemd[4054]: pipewire.service: Scheduled restart job, restart counter i>
May 12 23:19:42 admin-latitudee5550 systemd[4054]: Stopped PipeWire Multimedia Service.
May 12 23:19:42 admin-latitudee5550 systemd[4054]: pipewire.service: Start request repeated too quickly.
May 12 23:19:42 admin-latitudee5550 systemd[4054]: pipewire.service: Failed with result 'exit-code'.
May 12 23:19:42 admin-latitudee5550 systemd[4054]: Failed to start PipeWire Multimedia Service.
systemctl status --user pipewire-pulse
● pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; preset: enabled)
Active: active (running) since Fri 2023-05-12 23:19:41 WAT; 9min ago
TriggeredBy: ● pipewire-pulse.socket
Main PID: 12090 (pipewire-pulse)
Tasks: 2 (limit: 14144)
Memory: 1.6M
CPU: 33ms
CGroup: /user.slice/user-1001.slice/[email protected]/session.slice/pipewire-pulse.service
└─12090 /usr/bin/pipewire-pulse
May 12 23:19:41 admin-latitudee5550 systemd[4054]: Started PipeWire PulseAudio.
May 12 23:21:36 admin-latitudee5550 pipewire-pulse[12090]: mod.protocol-pulse: 0x55ff0ef64ab0: failed to conn>
May 12 23:21:36 admin-latitudee5550 pipewire-pulse[12090]: mod.protocol-pulse: client 0x55ff0ef83880 [Firefox>
systemctl status --user wireplumber
○ wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
Active: inactive (dead) since Fri 2023-05-12 23:19:42 WAT; 10min ago
Duration: 23ms
Process: 12101 ExecStart=/usr/bin/wireplumber (code=killed, signal=TERM)
Main PID: 12101 (code=killed, signal=TERM)
CPU: 19ms
May 12 23:19:42 admin-latitudee5550 systemd[4054]: Started Multimedia Service Session Manager.
May 12 23:19:42 admin-latitudee5550 systemd[4054]: Stopping Multimedia Service Session Manager...
May 12 23:19:42 admin-latitudee5550 systemd[4054]: Stopped Multimedia Service Session Manager.
May 12 23:19:42 admin-latitudee5550 systemd[4054]: Dependency failed for Multimedia Service Session Manager.
May 12 23:19:42 admin-latitudee5550 systemd[4054]: wireplumber.service: Job wireplumber.service/start failed >
Kernel: 6.1.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f6e631a5-e2d8-413f-a8f4-bbbf2118d400 rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: Dell product: Latitude E5550 v: N/A
serial: Chassis: type: 9 serial:
Mobo: Dell model: 0TR3VC v: A00 serial: UEFI: Dell
v: A13 date: 06/23/2016
ID-1: BAT0 charge: 19.2 Wh (73.6%) condition: 26.1/38.8 Wh (67.3%)
volts: 12.6 min: 11.4 model: Samsung SDI DELL R5MD0D9 type: Li-poly
serial: status: charging
Info: model: Intel Core i7-5600U bits: 64 type: MT MCP arch: Broadwell
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2478 high: 3082 min/max: 500/3200 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1673 2: 2616 3: 2541
4: 3082 bogomips: 20750
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-1.6:4 chip-ID: 0c45:6709 class-ID: 0e02
Display: x11 server: [X.Org](http://X.Org) v: 21.1.7 with: Xwayland v: 22.1.7
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c5 built: 2014 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
Sound API: ALSA v: k6.1.9-zen1-2-zen running: yes
Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
IF: eno1 state: down mac:
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp2s0 state: up mac:
Device-3: ZTE WCDMA MSM DEMO Mobile Boardband type: USB
driver: cdc_ether,usb-storage bus-ID: 2-2:14 chip-ID: 19d2:1405
class-ID: 0806 serial:
IF: enp0s20u2 state: up speed: 150 Mbps duplex: half mac:
IF-ID-1: br-7eaf0cfb76fd state: down mac:
IF-ID-2: br-e475deef7b8c state: down mac:
IF-ID-3: br-f508830f980c state: down mac:
IF-ID-4: br-fcb110c88bd4 state: down mac:
IF-ID-5: docker0 state: down mac:
bus-ID: 1-1.3:3 chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 476.94 GiB used: 92.6 GiB (19.4%)
ID-1: /dev/sda maj-min: 8:0 model: SSD 512GB size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial:
rev: 026D scheme: GPT
ID-1: / raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
used: 92.57 GiB (39.5%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 27.6 MiB (28.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
ID-4: /var/log raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
ID-5: /var/tmp raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.57 GiB used: 2.32 GiB (20.1%)
System Temperatures: cpu: 86.0 C mobo: 57.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 3706
Processes: 266 Uptime: 2h 19m wakeups: 2 Memory: 11.57 GiB
used: 6.85 GiB (59.2%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1965
libs: 532 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2022-09-16
Last full system update: 2023-02-19
Is partially upgraded: Yes
Failed units: [email protected]:dell::kbd_backlight.service systemd-vconsole-setup.service
I would really appreciate any support thanks.
Please format your post and post the garuda-inxi.
Since you didn't open your own topic, but posted in another, you also have no knowledge of the template, with its hints and requirements. Here in addition.
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively, read the tips on the Garuda Wiki:
Seems you delete it in the other new topic.
Cross posting is not helpfully and rude in forums, so I close it.
In terminal use
garuda-update
and reboot.
Kernel now is 6.3.1-zen2-1-zen
Yes I did a full system update and I also tried the following commands
systemctl --user enable pipewire.service
systemctl --user enable pipewire-pulse.service
and my audio worked the only thing left is that the control like the keyboard shortcuts are not working, Thanks
Use garuda-assistant and reset configs, remove latte dock it is out of date.
Reboot and check.
Open new help request if the problem exists, this topic is solved.
:smiley:
Thanks
