Audio mixer "raise maximum volume" button not working
The raise maximum volume button does nothing for me, except if i go into configure audio devices and raise them there. Then it shows up as being able to raise above 100%.
Is this a bug, or something misconfigured?
Kernel: 6.9.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=6a8a01fd-1dfe-48f8-8b4d-c2c38ad8ec88 rw rootflags=subvol=@
ipv6.disable=1 quiet resume=UUID=61fcd7d4-37c6-41ce-8991-c45faf6c34ec
loglevel=3 ipv6.disable=1 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop System: Gigabyte product: X570S AORUS PRO AX v: -CF
Mobo: Gigabyte model: X570S AORUS PRO AX serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F6c
date: 09/20/2023
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4080 high: 4550 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3640 2: 3640
3: 4550 4: 4498 5: 4525 6: 4299 7: 4450 8: 4510 9: 4299 10: 4377 11: 3599
12: 3599 13: 3639 14: 3640 15: 3640 16: 3640 17: 4550 18: 3638 19: 4513
20: 4511 21: 4383 22: 3659 23: 3614 24: 4521 bogomips: 177603
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3,Writeback-1 bus-ID: 0d:00.0
chip-ID: 1002:744c class-ID: 0300
gpu: amdgpu d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-1 pos: bottom-l res: 3440x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
navi31 LLVM 17.0.6 DRM 3.57 6.9.4-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 15 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab30
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS GameDAC driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2.2:7
chip-ID: 1038:1282 class-ID: 0300 serial: <filter>
API: ALSA v: k6.9.4-zen1-1-zen status: kernel-api with: aoss
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0608
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
IF: enp7s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-3:4
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
wpa_supplicant
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-5:2 chip-ID: 0e8d:0608
Local Storage: total: 4.32 TiB used: 1.66 TiB (38.4%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Kingston model: SNV2S500G
lanes: 4 tech: SSD serial: <filter> fw-rev: EJFK3N.7 temp: 69.8 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 58.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 054 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 2TB
ID-1: / raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
used: 231.68 GiB (53.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
ID-4: /var/log raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.23 GiB used: 321.8 MiB (1.0%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
ID-2: swap-2 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5
System Temperatures: cpu: 87.9 C mobo: 52.0 C gpu: amdgpu temp: 97.0 C
mem: 79.0 C
Memory: total: 32 GiB available: 31.24 GiB used: 15.21 GiB (48.7%)
Processes: 524 Power: uptime: 1h 15m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2150 libs: 574 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-04-19
Last full system update: 2024-06-16
Failed units:            nmb.service systemd-vconsole-setup.service
Increase from device option first then do here
Using this option can be risky. While it is convenient to use because of some files low volume levels, using this option has been known to damage speakers in the past. Using this option can result in high levels of distortion that could blow out speakers if turned up too high.
You may choose to disregard this warning, but you may regret it if an expensive set of speakers are attached to your system. Just FYI.
Nope, that’s not a bug, it’s a feature.
The raise maximum volume button only affects the devices, not the applications. Applications can normally only be set to 100%. The button is simply displayed on both tabs, but only applies to the devices.
I see. Thanks for the explanation
I had an application that for some unknown reason was running at 80% volume. Wanted to boost that application specifically.
