Hi,
I installed GARUDA DRAGONIZED on a CHUWY GEMIBOOK GEMI PRO ( a cheap brand. ok )
Everything it's ok except for audio ( and touchpad)
AUDIO says : JASPER LAKE HD AUDIO but not sound at all comes out
I just got sound from USB-C with earphones
BELOW the command you requested
( PULESEAUDIO running : NO ) ?
WHY?
If someone has some ideas and can help me i'll be grateful
THANX in ADVANCE
Alex
Kernel: 6.1.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=9c880935-afbb-4e45-b531-3432852e562b rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: CHUWI Innovation And (ShenZhen)c0.
product: GemiBook Pro v: JS131_V0.18.20 serial: <superuser required>
Mobo: JS131 model: N/A serial: <superuser required> UEFI: American
Megatrends LLC. v: JS131_V0.18.20 date: 10/15/2022
ID-1: BAT0 charge: 38.0 Wh (100.0%) condition: 38.0/38.0 Wh (100.0%)
volts: 7.6 min: N/A model: Intel SR 1 SR Real Battery type: Unknown
Info: model: Intel Celeron N5100 bits: 64 type: MCP arch: Alder Lake
level: v2 built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0x9C (156) stepping: 0 microcode: 0x24000023
desc: d-4x32 KiB; i-4x32 KiB L2: 1.5 MiB desc: 1x1.5 MiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 800 min/max: 800/2800 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 8908
Device-1: Intel JasperLake [UHD Graphics] vendor: nCipher Security
driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21
chip-ID: 8086:4e61 class-ID: 0300
Device-2: Sunplus Innovation Hy HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 1bcf:2ced class-ID: 0e02
Screen-1: 0 s-res: 2160x1440 s-dpi: 96 s-size: 571x381mm (22.48x15.00")
s-diag: 686mm (27.03")
Monitor-1: eDP-1 model: BOE Display 0x0893 built: 2019 res: 2160x1440
hz: 60 dpi: 185 gamma: 1.2 size: 296x197mm (11.65x7.76") diag: 356mm (14")
ratio: 3:2 modes: 2160x1440
API: OpenGL v: 4.6 Mesa 22.3.2 renderer: Mesa Intel UHD Graphics (JSL)
direct render: Yes
Device-1: Intel Jasper Lake HD Audio driver: sof-audio-pci-intel-icl
alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:4dc8 class-ID: 0401
Sound API: ALSA v: k6.1.2-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 160MHz driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:4df0 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-4.4:4 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20f0u4u4 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-8:6
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 253.03 GiB used: 37.53 GiB (14.8%)
ID-1: /dev/sda maj-min: 8:0 model: G521N 256GB size: 238.47 GiB
serial: <filter> rev: 227I scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Pop
size: 14.56 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.27 scheme: MBR
ID-1: / raw-size: 106.31 GiB size: 106.31 GiB (100.00%)
used: 37.53 GiB (35.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 106.31 GiB size: 106.31 GiB (100.00%)
ID-4: /var/log raw-size: 106.31 GiB size: 106.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 106.31 GiB size: 106.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.5 GiB used: 350.8 MiB (4.6%) priority: 100
System Temperatures: cpu: 90.0 C mobo: N/A
Processes: 245 Uptime: 23m wakeups: 1 Memory: 7.51 GiB
used: 5.52 GiB (73.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1300
libs: 348 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.13-1):
System install date: 2022-12-24
Last full system update: 2023-01-03
