Whenever I play an audio file on VLC it starts playing regularly, then has no audio for 0.5-1 seconds then continues normally. Not been able to find anything about it on the forums.
Specs:
Ryzen 4600U
16GB RAM
Kernel: 5.12.9-zen1-1-zen
Specs:
Ryzen 4600U
16GB RAM
Update your system, then check again.
Yes, because you are first with such issue. (I use vlc regularly, never had any problem)
inxi -Faz
What type of audio file are you trying to play. Have you tested other file formats such as FLAC, ogg, etc.
Have you tested alternate audio/video players? I would suggest testing smplayer, as well as one or two players dedicated to strictly playing audio.
You need to perform some basic troubleshooting to narrow down where the problem exists.
Troubleshooting entails eliminating different variables. When you have done some troubleshooting such as I've mentioned report back with your results.
