Hello.
I recently installed garuda linux last week and have been having a bug with the audio. Streamed media works fine, but for some reason local media (such as through mpv or vlc) is outputting at maximum volume despite the audio settings remaining at a lower volume level.
Post your terminal/konsole in- and output as text
System: Kernel: 5.14.2-zen1-2-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=4d053078-0b8f-4fe1-8037-4ef468ae3c0d
rw rootflags=subvol=@ splash rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=UUID=198d25c4-3386-48c4-b448-79be5f51ca9a loglevel=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Micro-Star product: GS63VR 7RF v: REV:1.0 serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16K2 v: REV:1.0 serial: <filter> UEFI: American Megatrends
v: E16K2IMS.310 date: 04/07/2017
Battery: ID-1: BAT1 charge: 52.0 Wh (97.0%) condition: 53.6/65.0 Wh (82.5%) volts: 12.8 min: 11.4
model: MSI BIF0_9 type: Li-ion serial: N/A status: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 serial: <filter>
CPU: Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44798
Speed: 3484 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3484 2: 3568 3: 3071 4: 3504
5: 3582 6: 3472 7: 3642 8: 3495
Graphics: Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Micro-Star MSI driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c20 class-ID: 0300
Device-3: Acer NEC HD WebCam type: USB driver: uvcvideo bus-ID: 1-11:7 chip-ID: 5986:0547
Screen-1: 0 s-res: 4480x1440 s-dpi: 108 s-size: 1053x341mm (41.5x13.4") s-diag: 1107mm (43.6")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: NVIDIA GeForce GTX 1060/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.14.2-zen1-2-zen running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Network: Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Micro-Star MSI driver: alx
v: kernel port: d000 bus-ID: 3d:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF: enp61s0 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: d000 bus-ID: 3e:00.0
chip-ID: 8086:24fd class-ID: 0280
IF: wlp62s0 state: up mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-10:6
chip-ID: 8087:0a2b class-ID: e001
Drives: Local Storage: total: 4.78 TiB used: 1.43 TiB (29.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: THNSNJ256G8NY size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0101 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
serial: <filter> rev: SDM1 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital model: WD My Passport 25E4
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 4005
Partition: ID-1: / raw-size: 221.14 GiB size: 221.14 GiB (100.00%) used: 74.42 GiB (33.7%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 221.14 GiB size: 221.14 GiB (100.00%) used: 74.42 GiB (33.7%) fs: btrfs
ID-4: /var/log raw-size: 221.14 GiB size: 221.14 GiB (100.00%) used: 74.42 GiB (33.7%)
ID-5: /var/tmp raw-size: 221.14 GiB size: 221.14 GiB (100.00%) used: 74.42 GiB (33.7%)
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 70.5 C mobo: 27.8 C gpu: nvidia temp: 63 C
Info: Processes: 297 Uptime: 8h 42m wakeups: 26 Memory: 15.52 GiB used: 8.4 GiB (54.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1496 pacman: 1490
lib: 456 flatpak: 6 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
