after update linux-zen 5.19.9-zen1-1 or other kernel 5.19.9
audio interface audient id4 is inactive
in systemsettings audio
inactive cards
audient id4 profiles --> off
garuda-inix
Device-4: Audient iD4 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-7:6 chip-ID: 2708:0009 class-ID: fe01
Sound Server-1: ALSA v: k5.19.9-zen1-1-zen running: yes
how to rollback old kernel or correct for new kernel
d3v0r4k
September 20, 2022, 8:15am
2
for rolling back to an old kernel you can use sudo pacman -S linux-zen linux-zen-headers
and choose the desired kernel and appropriate headers, and when prompted choose yes to block the kernel from future update.
the best advice will be not to downgrade but to use the linux-lts
kerne .
report the kernel developers.
thank you
linux-lts 5.15.68-1 or other kernel 5.15.68-1
same problem
d3v0r4k
September 21, 2022, 7:30pm
4
Then try a kernel that was working before, or use a snapshot where the device was working fine.
Most of your inxi
output is missing somehow; practically no system information is visible. Can you try pasting again?
before linux-zen 5.19.9 or lts 5.15.68 it's work
after 5.19.9 or lts 5.15.68 profile --> off
maybe have some change in kernel
Kernel: 5.19.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1a9a0a75-d8c6-46ca-bdfe-b450f1c3fb39 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.80 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 2
Type: Desktop System: HP product: HP Z240 Tower Workstation v: N/A
Mobo: HP model: 802F serial: <superuser required> UEFI: HP v: N51 Ver.
01.83 date: 03/08/2022
Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 built: 2015 process: Intel 14nm family: 6
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1837 high: 3400 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 3400 6: 3400 7: 897 8: 3400 bogomips: 54398
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107GL [Quadro P620] driver: nvidia v: 515.65.01
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-08) arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1cb6
Screen-1: 0 s-res: 6486x2160 s-dpi: 80 s-size: 2059x686mm (81.06x27.01")
s-diag: 2170mm (85.44")
Monitor-1: DP-4 pos: right res: 3840x2160 hz: 60 dpi: 163
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-2: DP-6 pos: primary,left res: 2560x1080 hz: 60 dpi: 81
size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
vendor: Hewlett-Packard driver: snd_hda_intel bus-ID: 1-2:3 v: kernel
bus-ID: 00:1f.3 chip-ID: 0b05:17f5 chip-ID: 8086:a170 class-ID: 0300
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
chip-ID: 10de:0fb9 class-ID: 0403
Device-3: ASUSTek Xonar U5 sound card type: USB
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
port: 4020 bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 1.36 TiB used: 46.52 GiB (3.3%)
model: WDS500G3XHC-00SJG0 size: 465.76 GiB block-size: physical: 512 B
rev: 102000WD temp: 44.9 C scheme: GPT
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A800
scheme: MBR
ID-1: / raw-size: 265.47 GiB size: 265.47 GiB (100.00%) used: 46.52 GiB
(17.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 760 KiB
ID-3: /home raw-size: 265.47 GiB size: 265.47 GiB (100.00%) used: 46.52
GiB (17.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 265.47 GiB size: 265.47 GiB (100.00%) used: 46.52
ID-5: /var/tmp raw-size: 265.47 GiB size: 265.47 GiB (100.00%) used: 46.52
System Temperatures: cpu: 37.0 C pch: 67.5 C mobo: N/A gpu: nvidia
temp: 54 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Processes: 246 Uptime: 4m wakeups: 0 Memory: 31.27 GiB used: 2.19 GiB
(7.0%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 alt: 11 Packages: pm: pacman pkgs: 1630 libs: 430
tools: pamac,paru Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
Garuda (2.6.7.r0.g59d794d-1):
System install date: 2022-09-22
Last full system update: 2022-09-22
filo
September 22, 2022, 5:12am
8
You probably already came across this. Just in case...
To downgrade a package or the kernel
https://wiki.archlinux.org/title/Downgrading_packages#Downgrading_the_kernel
Or use the downgrade command (see Automation in that wiki page).
But also switching, maybe temporarily, to pulseaudio could be an option.
I test by install garuda-kde-lite
linux-zen 5.19.7zen2-1 pipewire 3.57 alsa-card-profile 3.57
it's work
after upgrade only linux-zen 5.19.9zen1-1
linux-zen 5.19.9zen1-1 pipewire 3.57 alsa-card-profile 3.57
inactive card audient id4 profile --> off
now I use linux-rt for aviod upgrad kernel
system
Closed
September 24, 2022, 6:41am
10
