Audacity Audio recording not working
Hi, audacity has never worked but I need it for my job and I would like to have it working on my daily-driver, does anybody know of the issue that I'm having?
I always get the same loud static when recording anything at all from any mic. Do you know what I'm doing wrong?
Because I keep getting this error but I'm not quite sure how to resolve this:
22:36:25: Debug: PortAudio stream error creating device list: JACK Audio Connection Kit:Built-in Audio Analog Stereo: Invalid sample rate
22:36:25: Debug: PortAudio stream error creating device list: JACK Audio Connection Kit:easyeffects_filter: Invalid sample rate
22:36:25: Debug: PortAudio stream error creating device list: JACK Audio Connection Kit:spotify: Invalid sample rate
22:36:25: Debug: PortAudio stream error creating device list: JACK Audio Connection Kit:Built-in Audio Analog Stereo Monitor: Invalid sample rate
22:36:25: Debug: PortAudio stream error creating device list: JACK Audio Connection Kit:HDA NVidia Digital Stereo (HDMI) Monitor: Invalid sample rate
22:36:25: Debug: PortAudio stream error creating device list: JACK Audio Connection Kit:JamesDSP Sink Monitor: Invalid sample rate
Also, garuda-inxi:
  Kernel: 5.18.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=5411b7ff-d53c-4780-9b50-82a7b4183826 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 info: latte-dock
  Type: Laptop System: Acer product: Nitro AN515-57 v: V1.10
  Mobo: TGL model: Scala_TLS v: V1.10 serial: <superuser required>
    UEFI: Insyde v: 1.10 date: 09/19/2021
  ID-1: BAT1 charge: 24.1 Wh (42.9%) condition: 56.2/57.5 Wh (97.8%)
    volts: 14.9 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
    status: discharging cycles: 202
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
    charge: 5% (should be ignored) rechargeable: yes status: discharging
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
    model-id: 0x8D (141) stepping: 1 microcode: 0x3E
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1237 high: 2977 min/max: 800/4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 933 2: 1072 3: 984
    4: 1584 5: 1327 6: 801 7: 801 8: 1340 9: 1552 10: 1168 11: 1022 12: 840
    13: 2977 14: 788 15: 1614 16: 1001 bogomips: 73728
  Device-1: Intel TigerLake-H GT1 [UHD Graphics]
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen12.1
    process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: DP-1,DP-2
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile]
    vendor: Acer Incorporated ALI driver: nvidia v: 515.48.07
    alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
    built: 2020-22 bus-ID: 0000:01:00.0 chip-ID: 10de:25a2 class-ID: 0300
  Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-9:3
    chip-ID: 0408:a061 class-ID: 0e02
    compositor: kwin_x11 driver: X: loaded: intel,nvidia
    unloaded: modesetting,nouveau,vesa alternate: fbdev,nv gpu: i915
    s-diag: 1052mm (41.43")
  Monitor-1: HDMI-1-0 pos: primary,right res: 1920x1080 dpi: 81
    size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
  Monitor-2: eDP1 pos: primary,left res: 1920x1080 hz: 144 dpi: 143
    size: 340x190mm (13.39x7.48") diag: 389mm (15.33") modes: N/A
  OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.2
    direct render: Yes
  Device-1: Intel Tiger Lake-H HD Audio driver: snd_hda_intel v: kernel
    alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:43c8
  Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
    v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
  Sound Server-1: ALSA v: k5.18.5-zen1-1-zen running: yes
  Sound Server-4: PipeWire v: 0.3.52 running: yes
  Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:43f0
  Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
    port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:2600 class-ID: 0200
  IF: enp44s0 state: down mac: <filter>
    bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
    class-ID: 0104
  Local Storage: total: 2.29 TiB used: 1.05 TiB (46.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41020C20
    temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
    type: SSD serial: <filter> rev: 2B6Q scheme: MBR
  ID-1: / raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
    used: 242.64 GiB (81.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
    used: 50.5 MiB (52.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
  ID-4: /var/log raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
  ID-5: /var/tmp raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 27.8 C mobo: N/A
  Processes: 366 Uptime: 14m wakeups: 4 Memory: 15.41 GiB
  used: 4.32 GiB (28.1%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 2055
  lib: 529 Shell: Bash v: 5.1.16 running-in: terminator inxi: 3.3.18
Garuda (2.6.4-1):
  System install date:     2022-02-16
  Last full system update: 2022-06-22
The wiki gets a little dense here, but if you manage to stick with it this page describes how to change the sample rate in PipeWire: PipeWire - ArchWiki
The issue still persists but sample rate is no longer the problem
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-amp>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib64/lv2/eg-amp.lv2/
lilv_world_add_plugin(): warning: ... and      file:///usr/lib/lv2/eg-amp.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-fifths>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib64/lv2/eg-fifths.lv2/
lilv_world_add_plugin(): warning: ... and      file:///usr/lib/lv2/eg-fifths.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-metro>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib64/lv2/eg-metro.lv2/
lilv_world_add_plugin(): warning: ... and      file:///usr/lib/lv2/eg-metro.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-midigate>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib64/lv2/eg-midigate.lv2/
lilv_world_add_plugin(): warning: ... and      file:///usr/lib/lv2/eg-midigate.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-params>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib64/lv2/eg-params.lv2/
lilv_world_add_plugin(): warning: ... and      file:///usr/lib/lv2/eg-params.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-sampler>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib64/lv2/eg-sampler.lv2/
lilv_world_add_plugin(): warning: ... and      file:///usr/lib/lv2/eg-sampler.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-scope#Mono>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib64/lv2/eg-scope.lv2/
lilv_world_add_plugin(): warning: ... and      file:///usr/lib/lv2/eg-scope.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-scope#Stereo>
lilv_world_add_plugin(): warning: Duplicate plugin <http://vital.audio>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib64/lv2/Vital.lv2/
lilv_world_add_plugin(): warning: ... and      file:///usr/lib/lv2/Vital.lv2/ (ignored)
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:877:(find_matching_chmap) Found no matching channel map
ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib pcm_a52.c:1001:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:482:(_snd_pcm_usb_stream_open) Invalid card 'card'
14:58:13: Debug: ScreenToClient cannot work when toplevel window is not shown
14:58:13: Debug: ClientToScreen cannot work when toplevel window is not shown
14:58:13: Debug: Warning: command doesn't exist: 'Cut'
14:58:13: Debug: Warning: command doesn't exist: 'Copy'
14:58:13: Debug: Warning: command doesn't exist: 'Paste'
14:58:13: Debug: Warning: command doesn't exist: 'Trim'
14:58:13: Debug: Warning: command doesn't exist: 'Silence'
14:58:13: Debug: Warning: command doesn't exist: 'Undo'
14:58:13: Debug: Warning: command doesn't exist: 'Redo'
14:58:13: Debug: Warning: command doesn't exist: 'ZoomIn'
14:58:13: Debug: Warning: command doesn't exist: 'ZoomOut'
14:58:13: Debug: Warning: command doesn't exist: 'ZoomToggle'
14:58:13: Debug: Warning: command doesn't exist: 'ZoomSel'
14:58:13: Debug: Warning: command doesn't exist: 'FitInWindow'
14:58:13: Debug: "Left" must use modifiers to be used as a keyboard accelerator with GTK
14:58:13: Debug: "Right" must use modifiers to be used as a keyboard accelerator with GTK
14:58:13: Debug: "Up" must use modifiers to be used as a keyboard accelerator with GTK
14:58:13: Debug: "Down" must use modifiers to be used as a keyboard accelerator with GTK
14:58:13: Debug: Unrecognized accel key 'NUMPAD_ENTER', accel string ignored.
14:58:16: Debug: AudioIO::GetBestRate() for capture
14:58:16: Debug: GetBestRate() suggested rate 44100 Hz
14:58:17: Debug: GetBestRate() Returning 44100 Hz
This is not an issue with audacity I don't think because Discord has the same issue, but only more recently
I've looked across multiple forums of arch based distros and only found solutions to my type of problem involving the playing of audio, not the recording. Again, I must reinstate that is not a problem with AUDACITY but system wide. This was not always the case but now the issue is system wide.
