Attem to write a read only database
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
When I log in Garuda linux then show a pop-up dialog text read only file system $HOME
Please read again the new topic template (that you should have deleted, but only after providing the required informazioni) :wink: and edit your post accordingly.
